Suggs's Avatar
Send a message via ICQ to Suggs
DME Relay Location
Hi all,
I think my DME relay has expired (wont start, clicking from fuel pump / starter ?). I have a spare (came with the car), but being non technical I would appreciate some advice on where it lives in the car so that I can change it.
Lee
911 1989 3.2 Carrera
928 1989 S4 RIP
Old 05-11-2006, 10:59 PM
aj88cab's Avatar
Lee
Please clarify, the engine will still crank if the DME relay is bad, it just will not fire (no fuel). If it is not turning over it is most likely something else. In any case the DME relay is under the drivers seat next to the DME "brain".
Good Luck
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 05-11-2006, 11:18 PM
Suggs's Avatar
DME Relay - possibly
The engine will not crank, onthe turn of the key it "clicks" from the front but does not turn over.
Ideas welcome, the engine is not seized as it turns by the hand. I do not think the immobiliser is faulty. It seems electrical.
I will phone my mechanic and report back his thougts !!
Cheers
L
928 1989 S4 RIP
Old 05-12-2006, 12:57 AM
KCinBR's Avatar
Based on what you have said... I would start with making sure the battery is good. If it is then I would check the starter.
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 05-12-2006, 02:10 AM
MBEngineering's Avatar
HI sounds like the starter solinoid or earth connection, the DME relay is under your pass' seat (if it is RHD) should not stop the engine turning over
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 05-12-2006, 04:17 AM
Leadfoot Geezer
rcooled's Avatar
Dead battery.
'13 BMW 335i coupe - current DD
Old 05-12-2006, 07:19 AM
Location: member Central PA Region PCA , Home of the Hershey Swap
I'd bet money on a Dead battery. Just had to replace mine before The Glen this week.
Frequent Pelican Customer
1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more
2002 996 TT X50 (H&R Springs)
2002 WRX in WRX Blue
Proud Rennlist Charter Member
Support and Join Rennlist.com
An Expert on absolutely nothin' more than my own opinions!
Old 05-12-2006, 07:26 AM
