avendlerdp's Avatar
The Pertronix ingitor is a way better way to ditch ponts with MSD than any optical system. No extra box either.
1972 Porsche 914 Project
2000 BMW M5
1973 Aermacchi 350
Old 05-14-2006, 08:29 AM
One thing you need to watch is the fact that some coils need to be mounted upright or they will begin to ozzz goo and eventually fail. Usually they will say the coil can be mounted in any orientation if that is the case.
Dennis H. 72 911E 2.7 RS stuff
72 911T with a 2.7(Sold 5-13-2011)
2012 Kona Blue Metallic Mustang GT Convertible 6spd
67 Mustang coupe future SVRA group 6 car
63 Falcon hardtop 302/4spd
Old 05-14-2006, 08:42 AM
GOT TURBO..
MobileWrks's Avatar
LOL vash..
I use a philip screw driver. Wrap it around and as you have about 6 coils push them close together.. Larger srew driver, larger coils..
Old 05-14-2006, 07:59 PM
lateapex911's Avatar
Regarding the Pertronix, do a search here. The quality seems to be iffy. Lots of DOA or just plain failures.
The "Hi vibe" version of the MSD coil is intended for inverted mounting.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 05-15-2006, 10:59 AM
Gon fix it with me hammer
svandamme's Avatar
i've got an high vibration epoxy flamethrowerl coil from pertronix, cause the msd importer here is a crappy outfit that couldn't get it delivered in over a month...the flamethrower works like a charm on my car... i don't see how an epoxy coil could care about it's mounting position... there's no oil, epoxy is solid...
and a nice touch , the flamethrower is nice black
remove the sticker, and it's very low key
unlike the flashy red for msd
Stijn Vandamme
BIMDIESELBMW116D2019
Old 05-15-2006, 11:59 AM
47silver's Avatar
msd pertronix
the msd came with the car 4 years ago,, i added pertronix 2 years ago,,,starts (knock on wood) everytime and runs to the limit very quickly.
do not have any experience with the bosch but found that the black wire on the points was rubbing on the distributor cam intermittently, causing tons of problems. As a result i eplaced the points with a so that is why i put in a pertronix which has worked nicely.
1975 911S Targa
Silver Anniversary Edition
Old 05-15-2006, 05:55 PM
araine901's Avatar
10 years on my MSD 6AL + Pertronix. No probs. Better low end running, Makes adjusting carbs much easier.
'66 911 (sold to Magnus Walker)
'63 Myers Manx
'67 Cal Bug
'02 GTI 1.8T
Old 05-15-2006, 07:08 PM
