-   -   BAE Turbo Install, Part 1 (http://forums.pelicanparts.com/porsche-911-technical-forum/283457-bae-turbo-install-part-1-a.html)
tsuter 08-12-2006 03:14 PM
I wouldn't worry that it does not spin on as long as it's not impacting the housing. When you got hot exhaust in there it'll spin. While everything is out this would be a good time to relocate the thermotime switch to the passenger side. You'll see why after the motor is back in and your fitting the turbo inlet pipe.
patkeefe 08-12-2006 04:34 PM
tsuter
Just did that relocation (yup, I read your posts religiously). Luckily, my covers have a fitting on both R and L sides. My TT switch was cracked, and the wires were fried. I fixed the wiring, but need to test the TT switch. Could you verify that it's NO, and when it warms up, goes closed to short the supplemental fuel valve (I think thats how it works)?
Gotta go to the Home Depot and get some little fittings for the boost controller and the boost gauge. I bought the $40 gauge in lieu of the $230 model. The el cheapo Stewart Warner only gives you enough tubing to do a Chevrolet, a bit short on the 911.
Sure can change the CIS manifolds pretty quick while the engine is out.
Heres my intercooler:
http://forums.pelicanparts.com/uploa...1155425558.jpg
http://forums.pelicanparts.com/uploa...1155425598.jpg
tsuter 08-12-2006 05:35 PM
The thermotime switch provides the ground for the CSV hence my understanding is that it is closed when cold and open when hot. So I would say it is an NC switch when cold and an NO switch when hot. But I don't have the electrical diagram handy.
edit: but if it works as a short for the CSV then it would be the opposite.... NO cold and NC hot. Sorry..........
patkeefe 08-12-2006 05:49 PM
tsuter, I just read up on the wiring...you are correct NO cold and NC hot. Thanks!
I think the way it was is that it either never worked, or injected fuel all the time on the CSV. I will verify its operation when I get the thing running via the trusty jumper wire.
Pat
mb911 08-13-2006 06:30 AM
Originally posted by quattrorunner
Ben, are you going to use the BB turbo?
Yup thats what I am currently running on mine
patkeefe 08-13-2006 01:21 PM
Would I want the vacuum line to the distributor below (downstream) of the throttle butterfly?
And, I checked my TT switch. I have continuity when cold, so it's NC cold, but I still have to get some voltage and see just what the heck it's really supposed to do. Bentley says its NC cold. Maybe that's why the CIS ran rich all the time.
patkeefe 08-13-2006 02:01 PM
And, do I really need the auxiliary air valve?
patkeefe 08-13-2006 05:35 PM
Progress is sometimes slow. I have to rethink just about every step along the way, as this is all new to me, no matter how many times I read and reread the available stuff on this board. Every step has some glitch in it, some big, some little. Never have the right size or quantity of pipe fittings, or tubing, or hose. Totally hacked the left side engine tin to clear the turbo. On and on. I hope the AAV has a check in it, as I don't see what will keep it from bypassing air on boost transition.
Progress:
http://forums.pelicanparts.com/uploa...1155515300.jpg
http://forums.pelicanparts.com/uploa...1155515366.jpg
I sure hope this water injector system I'm putting in works. Works pretty well on 600 HP supercharged Corvettes.
Pat
tsuter 08-13-2006 05:49 PM
It will be fine. Don't take it out. It won't pass air under boost.
mb911 08-14-2006 05:35 AM
930 have them in there so as thad says don't worry
Tim Hancock 08-14-2006 05:40 AM
Pat, is your car butterscotch color? It looks like the original color of my '79 SC before it got a total respray of GP white. If you have a pic, I would like to see what your car looks like just out of curiousity.
patkeefe 08-14-2006 06:43 AM
Tim, yeah, it's the butterscotch Porsche, as my girls call it. It's Kashmir Beige. I have some pictures on the work computer, which won't boot at the moment. ARRRGGHHH
http://forums.pelicanparts.com/uploa...1155562949.jpg
patkeefe 08-14-2006 06:18 PM
Well, I got about as far as I can for now. The car ain't gonna make it to Watkins Glen for Friday AM, so I am turning my attention to prepping the 968 for the track.
I have most of the fuel and vacuum lines cobbled together, think I have it pretty figured out. Next week I can sit back and look it over before I put it back in the car, and hope it starts, doesn't make any bad noises, and makes boost.
http://forums.pelicanparts.com/uploa...1155604485.jpg
http://forums.pelicanparts.com/uploa...1155604626.jpg
tsuter 08-14-2006 06:43 PM
You probably got all this but make sure that both EGR nipples on the Throttle Body get capped or you'll have a nasty leak. Also the decel valve fitting needs a cap. You won't be hooking it back up. Looks like only one EGR is capped in the upper pic.
pjv911 08-14-2006 06:53 PM
Pat, what did you do about your dist advance/retard hose. Did you leave it off and set the timing at 6k rpm to make sure you have good total advance ? Or is the transition from vaccum to boost ok with it ?
I dont recall what I did when I had my BAE kit. But i think I would have left the distributor weights to do the job alone.
Kurt Williams
patkeefe 08-14-2006 06:56 PM
tsuter, thanks. You are correct, I need two more caps. I took the distributor feed from the old air pump port below the TB. I moved some stuff around, but it seems to make sense. I am unsure of the necessity of the thermal valve, as mine was capped originally. I had my decel valved neutered before; not a real nice feature at the track.
Where do you vent your oil tank? I really don't want to vent it back to the airbox. I'm thinking of a vent for crankcase and tank together into a little breather box, like on a track car. I don't see pressure equalization as a problem. I do know that the airbox and everything downstream was well oiled after years of use.
Pat
pjv911 08-14-2006 06:59 PM
Pat, the thermovalve it there to restrict vaccum to the distributor until the engine is warm. It has an internal coil that heats up and opens with time. In your case I would say just eliminate it.
BTW THE ENGINE LOOKS GREAT ! NICE WORK!
Kurt Williams
tsuter 08-14-2006 07:02 PM
Pat
I vented right back to the airbox. No big deal...passenger side. See the big clamp in pic. Just don't overfill a lot. :)
http://forums.pelicanparts.com/uploa...1155607326.jpg
patkeefe 08-14-2006 07:04 PM
Kurt:
I have the stock dist in there, no recurve at this time. I am installing a water injection system, which is acually pretty slick. I feel it will allow me to run the same settings I'm running now, the stock settings.
Plus, I have a wideband meter going in, so I will be able to see what kind of AFR I have at different timing. I generally use the farmer method-advance it til it detonates, and then back it off a few degrees, but that may not apply here too well. But, I did leave the hose on, relocated. I'll have to verify the vacuum operation when I get it running. I also have a boost controller, and an adjustable PE switch for the water injector, so I'll have a lot of variables to play around wih til I find the right setup.
Pat
patkeefe 08-14-2006 07:16 PM
Kurt:
Thanks for the compliment. I'm reserving judgement until I hear it run.
Pat
