-   -   BAE Turbo Install, Part 1 (http://forums.pelicanparts.com/porsche-911-technical-forum/283457-bae-turbo-install-part-1-a.html)
patkeefe 05-17-2006 06:07 PM
Well, the little 3.0 is leaking like a sieve anyway, so I guess now is as good a time as any to freshen the engine and put in the much traveled BAE turbo kit.
Tested the tubing to make sure it will fit:
http://forums.pelicanparts.com/uploa...1147914024.jpg
http://forums.pelicanparts.com/uploa...1147914086.jpg
Gotta remove the engine before one can rebuild it:
http://forums.pelicanparts.com/uploa...1147914157.jpg
I'll work on getting it apart tomorrow, then its off to the machine shop.
Thanks for the inspiration to, among others, tsuter, imchappy, air-cool-me, pjv911 and all of you low budget turbo guys, and to everyone who said "don't do it".
Pat
sammyg2 05-17-2006 06:31 PM
You will love the boost, in the same way a junkie loves crack. ;)
patkeefe 05-17-2006 06:49 PM
Yeah, I know I will. Plus, I'm tired of getting overpowered on the faster tracks. Please forgive me for omitting your name in the above post, as you are one of the main BAE boosters here.
iamchappy 05-17-2006 06:53 PM
Way to go Pat were here if you need us.
patkeefe 05-21-2006 12:06 PM
Do you think I was losing a bit of oil?
http://forums.pelicanparts.com/uploa...1148238221.jpg
http://forums.pelicanparts.com/uploa...1148238266.jpg
It's amazing how disarray comes with engine removal and disassembly...
http://forums.pelicanparts.com/uploa...1148238329.jpg
SLO-BOB 05-21-2006 12:24 PM
Now that's a Man's man's garage!;)
tsuter 05-21-2006 01:31 PM
Outstanding!!! Pump it up!!
patkeefe 05-21-2006 03:01 PM
The current plan is to rebuild the 3.0, and make it as bulletproof as I can within reason. I don't have any broken head studs (on the right side, at least), and I do have Nikasil cylinders. As soon as I get the rest apart, I'll check the wear and see where I am with the wear limits. I'd like to go with the original stuff, for cost reasons, plus it keeps with the intent of the original BAE design. Thankfully, there is lots of BAE info thanks to you turbo guys, such that I don't have to reinvent the wheel on this installation.
Todays question is regarding camshafts. I can easily stick with the SC cams, or go with something to take advantage of the compressor. I was looking over an Elgin spec, and they have a slightly modded profile which they say will work very well in this sort of application. Opinions???
Special thanks to the helper, just turned ten. She is quick with the Barbie jeep, just can't reach the handlebars and ground on the Dyna just yet.
http://forums.pelicanparts.com/uploa...1148248642.jpg
air-cool-me 05-21-2006 09:00 PM
thanks for the mention... !! good luck~!
feel free to give me a call(if you still have my number) if you have any questions.
speaking of much traveled... i ran into the owner before me and hes also a pelicanite!
patkeefe 05-23-2006 06:21 PM
Nick-It's good to keep this stuff in the family...
So, when I pulled the pistons out tonight, I foud that someone had marked the piston with numbers to match the cylinders, with an engraver. Somehow I doubt it was the factory that did that, so I will assume the engine was "rebuilt" before. The way that thing leaks, I can only say that the "rebuilder" did a somewhat hack job. He left the Dilavar studs on the exhausts. The pistons and cylinders look pretty good however.
Pat
patkeefe 05-28-2006 02:53 PM
Well, I got the CIS apart, and when I finally cleaned all the crud off the airbox, I figured I'd take it apart. The top and bottom sections of the plastic box (That is, the filter section, and the manifold attachment section, not the filter lid) won't come apart with a reasonable amount of force. So, I left them as is. Upon examination, I have found that there are big runs of dried epoxy at the joint, as though someone had GLUED THE BOX TOGETHER. I suspect that the facory would have done a neater job of this. So, I have concluded that the seam may have ruptured once, precipitating the install of the popoff valve.
Since I have never seen a "blown up" air box, anyone care to enlighten me as to what that would look like?
Anyway, I'm going to get a little fish scale, and see how much force it takes to raise the popoff off its seat. Maybe I can find a stiffer spring, if necessary.
Pat
tsuter 05-28-2006 03:28 PM
The top and bottom half are glued together and I don't think they are intended to come apart. A "blown" airbox can manifest in many ways including just a big irregular hole in the lower half side.
The pop valve will need to come out and the hole repaired or be completley glued shut as you will not be able to backload it with the 8-10psi needed for it not to open and leak under boost.
patkeefe 05-28-2006 03:33 PM
Thanks, tsuter. I guess the factory built that box on a Friday during Oktoberfest.
I was toying with the idea of getting a different spring, kind of like in a mousetrap. I guess I'd need a spring like from a NYC rattrap...they're rated for bigger rats down there.
tsuter 05-28-2006 03:41 PM
Here's an attempt that didn't work......
Pretty ghetto.....
http://forums.pelicanparts.com/uploa...1148856042.jpg
patkeefe 05-28-2006 04:18 PM
Yeah, I saw that in one of these threads. Nice workmanship.
http://www.isckc.com/torsion.htm
So, if I can find a torsion spring which will release before the box blows up...all I have to do is figure out the reversion pressure wave magnitude, which is some fraction of cylinder pressure...
quattrorunner 05-28-2006 05:02 PM
Anyone have a link to the thread about mounting the turbo in the fender area rather than in the back? I'd like to know why not.
Grezdlitn 05-29-2006 06:11 AM
I'm glad you posted this link on my CIS thread as I have 'BOOST' on the brain right now. Do you have a pic that shows the turbo mount and what type of turbo will you be running?
Have you considered build your own plenum out of aluminum and incorporating the existing cis parts? I've seen some threads that have pics of air-boxes that reposition the throttle body to achieve better airflow in a turbo situation.
I'm probably preaching to the choir but I recently picked up a book called Maximum Boost and it really got the juices flowing.
There's a turbo system in my future somewhere!
So much for my early morning "cross threading":D have a great memorial day!
Mark
patkeefe 05-29-2006 06:41 AM
Mark:
Do a search on BAE; lots of stuff. This link is the highlight:
http://forums.pelicanparts.com/showthread.php?s=&threadid=90065&highlight=bae+tur bo
Many good pictures in there, and tons of info. I have a Rajay T04B, which came with the old BAE kit.
And, yes, I am thinking about another aluminum airbox, which I will make up, unless I can find one already built. That may have to wait for the winter tweaking. My goal right now is to build the engine as bulletproof as possible, and get the turbo running in its current semi original BAE state.
Pat
quattrorunner 05-29-2006 09:32 AM
This is a great thread. Someone made quick comment about not placing the turbo in the fender area. I would like to know why not? I could remove some of the sheetmetal to place intake pipes there. Ijust want enough room in back for cat and muffler to exit the right side. Any thoughts?
sammyg2 05-29-2006 12:45 PM
This morning i finally decided to get off my butt and re-install the BAE turbo after getting the car smogged.
3 hours later (1 hour spent trying to remember where I put all the parts) I took it for a spin, wow. I forgot how good it feels.
The wide band O2 sensor and LM-1 is doing it's job. It's around stoich until i stomp on it, then it goes to 12 to 1 at WOT. Just where I want it.
Now to get cleaned up and go boost some more ;)
quattrorunner 06-02-2006 09:05 AM
Look ebau #
8069936259
patkeefe 06-10-2006 05:45 AM
The Satuday AM update:
I'm starting to get parts back from the shop, all of the internals came out ok. I'm going with the Raceware rod bolts, and 993 head studs. Cams went to the left coast to get reground to the DC-15 profile.
I'm seriously thinking about boost control, fuel enrichment, and putting the intercooler on. I think that the intercooler is absolutely necesssary at this point, since I will be taking the car to the track. Do any of you guys take your cars to he track, and how does a 25 minute run group effect the air inlet temps? I'm concerned about detonation.
Pat
tsuter 06-10-2006 06:50 AM
Its all about the boost. 6-8psi w enrichment, you won't need an intercooler with the CR of a 78SC. You just aren't creating that much heat. Now you get a little more greedy and want to run 10+psi.....
patkeefe 06-10-2006 07:13 AM
Thad, when I undertook this little project, I told myself not to get greedy, and I probably won't. After doing some calcs on the air inlet temps at 6 psi, I started to realize that I may start to see excessive air inlet temps. I didn't take into account the cooling effects of the fuel enrichment yet; I'm doing worst case. The problem is at the track, if the car is detonating, I won't be able to hear it with all the noise and a helmet on. Gotta find an air inlet temp gauge. I figure I could get a temperature rise of 140 F or so, which I feel will be too hot for sustained on boost operation. I keep the revs down around redline (6200 in my car) at the track, but with more HP comes an ability to get faster on the straights, so it will be tougher to moderate the revs...I don't have a rev limiter.
I have an intercooler from a 930, but I don't know what the performance specs are on it. Also, I really hate the idea of putting a tail on the car. I like the way it looks now, plain jane.
Grezdlitn 06-10-2006 09:02 AM
Pat,
I used a transmission temp sensor and guage that I purchased from Summit Racing. About $50. I use this in a turbo system I built for a experimental aircraft to track boosted air temps.
At full power at 16000 ft my air temps boosted run from 140 to 170 deg F. I don't know how this equates to ground runs but the Gage idea might be of use.
ANTONIO 06-10-2006 09:12 AM
Don't want intercooler?, use water injection., cheers, Ant.
patkeefe 06-10-2006 09:23 AM
Mark, what kind of ambient does the aircraft see at 16000 on the turbo inlet? Somewhere aound thw 30F range?
Maybe someday I'll finish the BD4 I started 28 years ago...wonder where all the parts are?
Grezdlitn 06-10-2006 09:40 AM
Pat,
That a tough question. It's all dependent on the time of year. I've seen ambient inlet tempsas low as16 deg in winter and as high as 59 deg in summer (at 16000).
Grezdlitn 06-10-2006 10:12 AM
Got interrupted! Tried inter-cooling for awhile but it didn't make much difference in my application. Biggest difference in temps came from increasing oil cooling capabilities thus lowering the overall temp of the turbo.
Seems to me that a controllable waste gate (BOV) would be the way to control temps. Monitor temps then dump boost if detonation likely?
Grezdlitn 06-10-2006 10:16 AM
BTW, I finished my RV-8 in two years but I have a Dragonfly scattered over several garages and storage sheds. It'll probably never see the air. You should resurrect the BD-4!SmileWavy
juicersr 06-11-2006 05:07 AM
Pat, you can put a stock intercooler under a ducatail... depending on whether you like the look, would allow yur ride to maintain its original character.
laughac 06-13-2006 07:39 PM
I bought a 6500 RPM rev-limiter distributor rotor for $30, and a BAE turbo kit from IronWil. The rotor works great as a rev-limiter.
Now I need to know the best place to attach the oil line(s) and signal tube before I install the turbo.
beepbeep 06-14-2006 02:03 AM
You don't need pop-off valve glued on airbox when going turbo. Turbo has a very long air-path betweens CIS and engine intake so backfire is very unlikely. You will never find 930 with blown filter-box.
Intercooler is a good thing to have, especially if you plan to track the car. It's easy to get greedy and turn up to boost. Intercooler gives you additional margin och power increase. I wholeheartedly recomend installing one, even if it's a compromised 3.3 OEM intercooler. Rear turbo wing also gives additional lift cancelation that's benefitial on track.
laughac 06-14-2006 06:14 AM
Thanks for calming my concerns about a pop-off valve. I guess the pop-off valve is only useful at low-rpms before any boost builds up.
I will look for an intercooler once the turbo is installed. My current turbo-look wing does not provide any additional clearance so I will probably go for an entire engine lid and new wing.
beepbeep 06-14-2006 06:24 AM
I think you are mixing things.
I'm talking backfire-protection pop valve that SC people usually glue on their airboxes. That particular gimmick is unnecessary on turbocharged cars. But there are two other compontents that people often mix up. They are Blow Off Valve and Wastegate. Both should be used.
I think you are talking about BOV. BOV is nothing else but a valve between turbo and intake that opens when you lift off the throttle after running on boost. It's only function is to release air that is pushed against closed throttle by spinning turbo when thottle is abruptly closed. There are two variants of those: open and closed. Open one produce particular "rice" whoosh sound and are to be avoided on CIS car. Reason for this is that air that is released is already measured by CIS and releasing it will make the motor go rich for and instant. Closed ones are quieter and re-circulate the air back into hose between CIS and turbo intake.
laughac 06-14-2006 06:46 AM
Good info! I hope the BAE kit came with a closed BOV. If it is complete then it probably does.
This morning I received the BAE instructions, so when I print them I can begin taking inventory and schedule the installation.
iamchappy 06-14-2006 06:52 AM
Chris the bov type valve on the BAE kit is their version of a wastegate which will control the boost pressure. There is no need for anything but ignition advance re-curving of the distributor with the kit in it's stock form.
Seal up the airbox pop valve with a plumbers compression pipe plug, they work great.
laughac 06-14-2006 06:59 AM
Will do and many thanks!
How can I be sure to get the right distributor re-curve kit? My '77 911 does not have a knock sensor and I only have ears for my exhast note.
beepbeep 06-14-2006 07:29 AM
BOV and wastegate are two completly parts that do different things.
There are some prehistoric ways of controlling boost pressure though. One of them was pop-off valve. It's nothing but spring-loaded valve that relieves the pressure from plenum at pre-set level.
It is very backward (albeit cheap) way of controlling boost and should be removed from any present installation. Those have bbeen used in dawn of automotive turbochargin era and subseqently replaced with wastegate/BOV in all designs save for maybe NASCAR.
sammyg2 06-14-2006 07:40 AM
I don't run an intercooler, but if I were to track the car for 25 minute races, i would install one for sure.
On the street we hit boost occasionally but not for sustained periods, unless we are really nuts.
On the track it's a different story. Boot is used more on the track than you could ever do on the street unless you are being chased by a channel 4 news helicopter ;)
I took mine to an autocross after the turbo install a few times, one was at irwindale speedway. it was a hot day and the track was fairly long and fast for an AX track. Lots of chances to get on boost.
There was very little wait time between laps so it was almost contunuous running for 10 or 15 minutes. Temps got fairly high and I thought I might have sensed pinging in 1st gear as I got the green flag on one of the last laps. My guess is that the entire intake system got heat soaked with every pass and eventually got too hot. An intercooler would have helped that.
