Help with shaking?
I haev a 1980 911SC w/ 117k miles. I get a vibration in the steering wheel at highway speed and it is most noticeable at 70MPH. If I go fatser it begins to subside but does nto go away completely. Periodically it will smooth out completely but only for a few seconds and then starts up again. If I grip the wheel real tight I can almost stop t from shaking.
I just replaced my ball joints because I thought that might be the problem but it seems like it only made it shake faster. I assume becasue the ball joints were worn or bad so I was not getting as much feedback from them as the new ones.
On my BMW it was the Idler arm which was a $20 fix but this car does not seem to have an idler arm.
Any suggestions?
Currently own:
1980 911SC slantnose
1991 Honda Accord -daily driver (1991 Honda Accord #2 - just because)
2003 Acura TL Type-S (2006 Honda Odyssey w/ DVD)
Gone but missed:
1988 Mazda RX-7 Turbo II (1991 Jeep Wrangler Renegade)
1984 Jeep CJ-7 (1994 Chevy Blazer)
1987 Chevy Corvette (1996 Mustang Cobra)
1993 Jeep Wrangler (1995 Mustang GT Conv.)
2003 Ford Explorer Sport Trac (1987 BMW M6)
Future: Hopefully not too far off
Ferrari Testarossa (Lamboghini Diablo or Countach)
Detomaso Pantera
Old 05-18-2006, 08:54 AM
MBruns for President
JeremyD's Avatar
Wheels need balanced? Did you shake off a wheel weight?
Old 05-18-2006, 08:55 AM
Designer King
Paulporsche's Avatar
How old are your tires?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-18-2006, 09:04 AM
Tires and wheels are new. I was thinking maybe it was jsut the tires that need balancing.
Currently own:
Gone but missed:
Detomaso Pantera
Old 05-18-2006, 09:05 AM
Designer King
It's possible. You had the wheels/tires balanced together when installed, right? There could be a defect in the tire, or a bad balancing job, or a wheel weight has come off, or maybe something else, like an out of balance brake rotor, a bad shock, or worn stering or suspension components. Alignment is also a possibility, but usually the symptoms don't change as the speed increases. Check your air pressures while you're at it.
Paul
Old 05-18-2006, 09:28 AM
The tires were mounted and balanced by the PO.
Currently own:
Gone but missed:
Detomaso Pantera
Old 05-18-2006, 09:34 AM
JeremyD's Avatar
Has it been sitting for a lengthy time? with todays softer high performance tires, they are easier to flat spot.
Old 05-18-2006, 12:16 PM
busteif's Avatar
Wheels shake
My 2 cents, I'm not a mechanic and don't know much about these cars but I had the same issue when I bought my 76-930 but thru a PPI inspection the mechanic told me about the violant shake and the need to change the front shocks. I did experience the same when I received the car driving at higher speeds. the car would shake pretty bad.
You have a 1980 with 117000 miles, my car has only 12,000 miles but the years of sitting erroted the shocks. have them checked, might be the problem for you I ended up upgrading mine to balestin sport shocks and changed all 4 now drives awsome.
Good Luck
Old 05-18-2006, 12:39 PM
Re-check the tires (balance and roundness) and check the wheels for trueness. Vibration over 65 is generally generated at the rear of the car.
Old 05-18-2006, 02:13 PM
disband
juanbenae's Avatar
a beer usually helps my shaking.
Old 05-18-2006, 03:21 PM
450knotOffice's Avatar
Alignment cured my steering wheel shakes when I first bough the car 1 1/2 years ago.
Old 05-18-2006, 07:28 PM
Immature Member
dentist90's Avatar
A vibration that you can drive thru usually indicates a balance problem. A flat spotted tire you can feel the vibration or thumping get progessively faster as you accelerate. Check wheel bearing adjustment, especially if vibration goes away if you slightly turn wheel. Checking for tire balance and roundness would be the simplest place to start. Rebalance should only set you back $10 per tire.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 05-18-2006, 09:59 PM
