| Senior Member Join Date: Jun 2000 Location: N. Phoenix AZ USA
			Mario, Stick with what Bill says and you will do fine. What part of Guatamala are you in? I lived in Guatamala City for a while way back in the '80's. Enjoyed the area and people. Was not able to explore as much as I wanted to as it was a bit "rough" at that time in the areas but would love to return someday.
				__________________ 2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB | ||
|  05-25-2006, 12:57 PM |
| Me like track days Join Date: Sep 2003 Location: Kirkland, WA
			If you are tracking a 3.6 Varioram car with stock 1976 brakes and are running at any sort of pace above beginner......you are quite frankly insane.      I mean this constructively - get better brakes. I'd recommend a C2 setup; Bill Verburg is a brake pad customer of mine and knows exactly how this is done.
				__________________ - Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno | ||
|  05-25-2006, 01:04 PM |
| Registered |
			Thanks Craig. I am beginner, but not insane. Got to the track ones with these brakes but not twice. I am already looking for alternatives to upgrade. I will probably go with 964/944t brake for now. I am trying to find a set of 993 calipers, but they are TOO expensive. Still not sure!!
				__________________ Mario '76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger '15 GT3 | ||
|  05-25-2006, 01:48 PM |
| Registered |
			Joeaksa, I live in Guatemala City also. I arrived only 4 months ago and I am really enjoying it. Thanks
|  05-25-2006, 02:08 PM |
| Moderator |
			C2 is too vague a referrence, 964 C2 will be marginal. 993C2 will be fine, as will 930, better is often bigger here.
				__________________ Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | | ||
|  05-25-2006, 02:16 PM |
			1990-1994 C2 brakes - this range is commonly called "C2".  Takes a 930 sized pad.  Pretty decent.  Readily available. 993 is......993. Takes quite a bit bigger pad and is much hard to find these calipers used. At any rate, what you have is flat out dangerous as-is.
|  05-25-2006, 02:30 PM |
| Registered |
			Bill, here is where I get confused. Fromyou site, I understood that 964 can used the same pads and rotors as the 930. Then why is that you are suggesting that 930 brakes would be fine, but 964s only marginal improvement? Thanks for the clarification.
|  05-25-2006, 02:37 PM |
| Moderator | Quote:
 The 993 calipers do not require the major machine operations that the 964 do.
|  05-25-2006, 04:11 PM |
| Moderator | Quote:
 Stock 283x20 & 290x20 are way too small for the weight and performanvce potential of your car as are 298x28 & 290x24 964 rotors 930 are 304x32 & 309x28 and are going to be the minimum to reliable work on track better would be 322x32 & 322x28 993RS rotors
|  05-25-2006, 04:19 PM |
| Moderator |
			PS the 993 calipers would go on 930 rotors
|  05-25-2006, 06:33 PM |
| Registered |
			Would $800 be a decent price for a set (frt & rear) of 993 calipers?? I am assuming another $600 for the rotors, is that ok? Thanks again
|  05-26-2006, 05:38 AM |
| Moderator | Quote:
 here's 1 front and 1 rear   the rear rotors are Pelican part # 911-352-041-08-M259 @ $90.50 ea. the best front rotors are Pelican part #930-351-048-00-M136 for a right front @ $399.75 and $407.75 for a left front. You would also need rotor hats and caliper adaptors in the front Steve W/ @ Rennsport can supply somewhat cheaper(I think) rotors and the other parts as well,
|  05-26-2006, 12:43 PM |
