busteif's Avatar
Power Window Problem!
Let me describe this as close as I can before you send me into search mode.
My passenger side window stopped working. (76-930) 2 switches on driver side and one on passenger side. driver side works fine but both passenger side switches do nothing the window stopped going up or down all the sudden?
I checked fuses and relay - seems fine - what to do?
thanks,
Old 05-23-2006, 08:16 PM
craigster59's Avatar
Replace/check the felt runner(s)?
Old 05-23-2006, 08:25 PM
those switches toast the delicate contacts.
I replaced all of mine after 100k mi. After 20yrs my car deserved $30
you could spend a few hrs tracking down the specific prob area thou..
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-23-2006, 08:47 PM
Check this
Yes could be the switches. If not check the body plug where the door wiring harness attaches to the body. It's up under the fender between the door and fender, There are two, one on both sides.
Old 05-24-2006, 04:11 AM
busteif's Avatar
passenger power windows
the switch makes a clicking sound when pushed downward but no sound at all when pushed upward? any idea.
Old 05-24-2006, 04:36 PM
Driving member
jester911's Avatar
Yeah, get a new switch. One of the few things on these cars that was probably underengineered. They go out fairly often.
But then we are talking about a 30 year old car so maybe not underengineered afterall
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 05-24-2006, 04:40 PM
busteif's Avatar
should I try using the driver side switch first before I purchase a new one. since the driver side switch works?
Old 05-24-2006, 04:45 PM
Driving member
jester911's Avatar
You might possibly break the switch you are wanting to move and then you will be out 2 switches. We are talking about an inexpensive part. Even if it is not the switch you are only out about 20 bucks. It is thirty years old man. Treat your car to a new thing or two
Jerry
Old 05-24-2006, 04:50 PM
David's Avatar
Most likely the switch, it could be the passenger switch on either door that's causing the problem. Last time I had this problem it was one on the driver's door.
Old 05-24-2006, 04:53 PM
busteif's Avatar
Hey Jester911,
The money isn't the issue here, the fact that we have a great form such as this to guide some of us that are less mechanically inclined then those of you is a blessing we appreciate.
anyhow, I had unplugged both the passenger switch from the driver side and plugged it back and did the same on the passenger side switch. now the window works from the driver side switch and the window goes up and down. strange but works. will buy a new switch for passenger side.
thanks for your help.
Old 05-24-2006, 04:59 PM
Wash. State
nesslar's Avatar
Craig?
Which of those wires is for the felt runner?
I think now that I've read enough of this thread, I'll "switch" to another one. You will certainly understand how I could have "felt" this way......
LOL
Old 06-23-2006, 12:29 PM
na2ub's Avatar
I had a similar problem. See my write-up.
Window Switch Repair
Doug
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 06-23-2006, 12:50 PM
jtkkz's Avatar
I have a similar problem, got a new switch and still did not work.
driver window = works
passenger window = works
driver side switch that opens passenger window = still does not work ???
Early Porsche Reproduction Products:
http://sycipworks.tripod.com/
Old 06-23-2006, 01:57 PM
The common connections for both passenger window switches would be power and ground. The passenger window switch on the drivers door is actually the master and the passenger side switch is the slave in regard to the power and ground routing. Here is a link to something I posted a couple of weeks ago that shows how the switches re-route the ground so that the motors work.
Power Window Switch schematic
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 06-23-2006, 04:59 PM
jtkkz's Avatar
I remember looking at that diagram, we were discussing this same problem.
I have my wiring color coded same and tried a new switch still does not work
It may look like a bad ground.... what do you think?
someone suggested a bad ground on the driver switch (passenger window) ?
Old 06-23-2006, 05:03 PM
jtkkz..if the passenger side window switch works that indicates that power is being applied to both sets of terminals on both switches. It would appear that you do not have a power issue. Because the passenger side window switch can operate the power window motor that indicates that the switch, the motor and the ground connections in the passenger door are all good.
Since you have replaced the passenger switch on the DRIVERS DOOR..that would lead me to think that the ground connection to THAT switch is bad. The schematic shows the ground going directly to the Drivers Side window switch with a short jumper going to the passenger window switch [on the drivers door]. That jumper may be bad. Have you attached a meter the that ground wire to test for continuity? Since you say that the drivers window switch works you could remove the ground wire from that switch and attach it to the neighboring passenger window switch to test this 'bad ground' theory.
Peace, Ron
www.ronorlando.net
Old 06-26-2006, 06:21 AM
