Banned
Got the MSD ignition installed now spark plug gaps?
Hey guys want to know what you guys set your gaps on the spark plugs for the 930 after installing the msd ignition kit, also what spark plugs you guys running? Thanks in advance
Old 05-23-2006, 10:35 PM
do a search. However, try this....
MSD plug gapping...
Old 05-23-2006, 11:39 PM
Steve Weiner says .040 w/MSD.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-24-2006, 01:02 AM
I did the .040 setting and had issues with it; unfortunately, I could not recall the specifics. I had to lessen the number to have a better performance.
However, that was before I installed my SSI and adjusting my mixture. I may have to revisit this .040 gap setting.
Old 05-24-2006, 07:35 AM
Originally posted by cab83_750
I did the .040 setting and had issues with it; unfortunately, I could not recall the specifics. .
maybe plug wire miss due to more current being drawn ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-24-2006, 12:19 PM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
Check MSD's site, they have a good set of instructions. I thought it was .050, but I could be wrong.
I installed a competitor's copy of the MSD 6AL, and haven't regapped the plugs, and it runs fine. (I haven't run the car all that much either)
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 05-24-2006, 12:22 PM
B D B D is offline
B D's Avatar
I'll second taking Steve's advice 0.40 is the best place to start. MSD does recommend .050 but that is a generic recommendation. I run mine just under .040.
Fray you should regap the plugs to take advantage of the larger spark these units deliver.
68 911L
Old 05-24-2006, 02:27 PM
