mark '87 930's Avatar
Any experience with this A/F gauge set
http://cgi.ebay.ca/AIR-FUEL-BOOST-GAUGE-PORSCHE-911-924-928-944-968-TURBO_W0QQitemZ4642868432QQcategoryZ6755QQssPageNa meZWDVWQQrdZ1QQcmdZViewItem
I'm more looking at buying them so I can use the A/F gauge as a tool to see where I am at. The boost gauge will be a reference..
Anyone had any luck with this vendor/gear. I've seen them on ebay for some time now. Thoughts?
I really don't want to buy anymore for my car... but I just can't help myself!
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 05-25-2006, 05:40 PM
I would recommend purchasing an LM-1 if your purpose is to use it as a tool. Those gauges look like Autometer knock offs BTW. :-)
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 05-25-2006, 05:44 PM
kuehl's Avatar
I don't believe those AFR's you are looking at are "wide band", for the price and display type they appear to be "narrow" band.
There are a over a dozen wide band AFR displays out there, we have been testing this one which is pretty easy to set up. It has an output feature and software to record to a laptop, AFR and RPM's. About the footprint of a credit card and 5/8" thick.
http://www.wmsracing.com/o2/index.htm
Pro's:
A) easy set up,
B) very long wire harness (remember most meters come
with short cables
C) AFR/RPM output for logging
D) free software
E) quick tech support
Cons:
A) rectangular box makes it difficult to find a location to mount, however I thought I saw a round meter on their site
B) though very accurate and responsive, when you are say idling in closed loop the 2 decimal display can be annoying, single decimal would have been good enough
Other AFR wide bands and info:
http://www.zeitronix.com/
http://techedge.com.au/vehicle/wbo2/
http://www.sdsefi.com/techegt.htm
http://www.innovatemotorsports.com/products/lm1.php
http://www.ontronic-efi.com/wideband.php
http://www.daytona-sensors.com/WEGO2.html
http://www.alamomotorsports.com/FJO/wbafr.htm
With regard to the "boost" gauge you noted, unless you are pushing over 10psi of boost the scaling is too great,
look for something that has a scale which will cover your boost range plus 50%, or simply find a good used 930 boost gauge.
Old 05-27-2006, 07:52 AM
My boost gauge in the car is functional, I am just concerned with it's accuracy. I wanted to put in a 1.0 bar spring, but it's seeming already pushing that according to the gauge. I think that .8 - 1.0 bar is equivalent to 11.6-14.5 PSI roughly.
The AFR gauges you pointed out are a good tool, but more than I wanted to pay.
1956 Chevy 3100
Old 05-27-2006, 02:29 PM
kuehl's Avatar
Yes, your conversion to psi is close enough (assuming sea level).
I guess you could rig up a "simple" AFR for $14.95 using this
http://www.autospeed.com/cgi-bin/browse.cgi?product=888800044
Old 05-27-2006, 08:40 PM
That's more the ticket. Thanks kuehl.
I will try that out. I will speak to them and hope that I can retain my O2 sensor to connect to this.
1956 Chevy 3100
Old 05-28-2006, 05:41 AM
kuehl's Avatar
just be aware of the limitation of accuracy, most AFR tuners
use wideband 02's for a reason, otherwise .... have some fun
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 05-28-2006, 06:34 AM
