Porsche virgin's Avatar
7" 951 wheel question
I just want to make sure I've got this right before I go spending any money.
I am considering putting 7" 951 wheels on the front of my '84 with '78 930 brakes. I have shaved the fins off of the calipers.
The car has been lowered to euro height, and it has stock torsion bars.
I have 8mm spacers all around, with 16x6 and 16x7 wheels now.
I also have a set of ROH 16x7 and 16x8 with 225/50 and 245/45 tires. They are heavy, though, and as we've discussed here, Fuchs just look right.
If I put my 911 7" on the front with 225/50-16 tires and my 8mm spacers, they stick out past the fender. I have tried this already.
Can I put the 951 7s on the front w/o a spacer? Will it clear my calipers?
I will probably use a 205/55 tire. The rubbing in turns when there is weight on the front drives me nuts.
I assume I won't have any problem getting 8s on the rear, either 911s with my 8mm spacer or 951s.
Thanks.
'08 RX350 (Hers)
'84 911 Carrera
'83 911SC Cabrio
'06 Miata
Old 05-26-2006, 10:10 AM
Jeff Alton's Avatar
The 951 7 wihtout spacer should clear your 930 caliper that has the fins machined. *should*
Cheers
www.turn3autosport.com
Old 05-26-2006, 12:07 PM
Monkey Wrench
Spede's Avatar
I have a 7" 951 fuch wheel without a tire that you can test fit if you'll pay for shipping both ways. Unfortunately, I'm on California. Fortunately though, a tireless fuchs is really light! The wheel is in pretty good shape so you'd have to promise to return it in the same condition that you receive it.
Old 05-26-2006, 12:13 PM
Bill Verburg's Avatar
I agree, it should clear easily
Bill Verburg
Old 05-26-2006, 01:00 PM
Thanks for your kind offer, Spede.
I'm pretty sure it will fit, but I wanted to hear it from one of the guys on the board. Thanks Bill and Jeff!
'08 RX350 (Hers)
'84 911 Carrera
'83 911SC Cabrio
'06 Miata
Old 05-26-2006, 01:16 PM
Non Compos Mentis
I know the 8" 951 rear is a unique wheel, but aren't all 7x16 fuchs the same? I think the 911 and 951 used the same wheel.
Anybody know for sure?
All I know is that I should have kept the Fuchs wheels when I sold the 951 I used to have.
Old 05-26-2006, 01:23 PM
Jeff Alton's Avatar
The 951 seven is different. It has the same offset but has much more caliper clearance. This gives the wheel an outward appearance very similar to that of the 911 6 inch wheel. Same way the 951 8 looks similar to a 911 7.
Cheers
Old 05-26-2006, 01:32 PM
No, there is a 911 version and a 944/951 version w/ more caliper clearance.
Bill Verburg
Ah, those sweet magic words...caliper clearance!
'08 RX350 (Hers)
'84 911 Carrera
'83 911SC Cabrio
'06 Miata
Old 05-26-2006, 01:38 PM
To be clear..although someone already said this.... the two different 7" Fuchs have the same backspace/offset.... so it might seem odd that the 951/944 model has more caliper clearance. It does...but *not* because of altered backspace..it simply is formed differently to gain more clearance...
I *think* the 951 version has the characteristic "deep lug holes" too ( vs. the 911 version which doesn't)..anyone confirm ??
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-26-2006, 06:48 PM
klaucke's Avatar
Yes Wil, the 951 Fuchs have the deep lug holes.
Old 05-26-2006, 06:50 PM
Jeff Alton's Avatar
echo?
Old 05-26-2006, 07:25 PM
simply confirmation per my request.... don't want to post erroneous info...doncha know !
Wil
Wil Ferch
Old 05-26-2006, 07:38 PM
Jeff Alton's Avatar
Sorry, my dry sense of humor doesn't always transmit across the keyboard that well!
Cheers
Old 05-26-2006, 07:39 PM
Wil and Jeff are on the case!
I'm hoping to sell my Miata soon and get in the market for a set of 951 7" and 8".
'08 RX350 (Hers)
'84 911 Carrera
'83 911SC Cabrio
'06 Miata
Old 05-26-2006, 08:17 PM
don911's Avatar
I give my personal guarantee they will fit.
My street wheels are 951 7s with no spacer on the front. I have 930 brakes with filed fins.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 05-26-2006, 08:39 PM
Now I just have to find a pair!
'08 RX350 (Hers)
'84 911 Carrera
'83 911SC Cabrio
'06 Miata
Old 05-27-2006, 02:21 AM
