Swank911's Avatar
Simple Corner Balance Question
What is the suggested fuel level when corner balancing?
Jon
'73 911e (ROW 3.0)
www.jonswanson.home.comcast.net
Old 05-26-2006, 11:29 AM
I believe this is an "open" interpretation of what is proper....
I would use 1/2 tank ....as the deviation ( toward full or toward empty)...is the "least worst".....
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-26-2006, 11:55 AM
RLJ RLJ is offline
Senior Registered User
I think a half a tank of fuel is pretty standard.
Don't forget to add weight to the driver seat to represent driver weight.
Best,
Randy Jones
1971 911 "Iris"
Old 05-26-2006, 12:20 PM
Here's a little gift factoid that I posted elsewhere on the impact of a 150 lb driver on the 4 corner weights, all assuming USA/Euro driver location...... you Brits and Japanese road drivers will want to mirror-image the numbers ..
Here is what adding a 150-151 lb driver does to the math, assuming his weight is in the driver's seat location. Each wheel-corner changes by this amount:
LF RF
LR RR
+62 +11
+50 +28
You can simply ratio your weight to this 151 lb weight...and get real close to what your 911 will be with your weight in it ( example : a 200 lb guy would have 200/151 of each of these values).
Wil Ferch
Old 05-26-2006, 12:40 PM
