Replacing ignition wires w/aftermarket - is it necessary to provide wire supports?
My '87 Carrera's OEM ignition wires are being replaced with Clewett wires. I've noticed the stock wires seem to have supports and separators built-into the assembly. How do you support and separate the new wires to keep them from rubbing against everything and wearing? Or is it really necessary? I notice the Clewett wires have a fabric reinforcement sheathing. Maybe that protects the insulation from wear due to rubbing?
Thanks!
Old 05-26-2006, 10:12 PM
Was planning to change the wires today and hoped to get an answer about this too.
Old 05-27-2006, 07:09 AM
I used Magnecores on my '87 with the factory supports and separators.
I had to slightly enlarge the factory holes for the larger wires.
Randy
'87 911 Targa
'17 Macan GTS
Old 05-27-2006, 07:22 AM
Somatic Negative Optimist
Gunter's Avatar
movin: Yes, you want to make sure that the ignition wires (And any other wires) are kept away from heat and rubbing.
Don't let them touch any of the engine parts that get very hot.
You can get seperators from Napa etc.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-27-2006, 07:55 AM
schnellmann's Avatar
All you really need to do is to drill out the stock separators to ever so slightly less than the diameter of the new wires and bolt them back as you found them.
After removing them from the motor, snap them back together so you can use the stock opening/tunnel as a guide hole. Drill slowly, though, and use a sharp bit to avoid cracking. Works great, takes less than five minutes total.
-Troy
88 3.4L Coupe
Old 05-27-2006, 09:49 AM
Thanks, I thought the OEM separators were bonded to the original wires, I'll re-use them after drilling out.
Old 05-27-2006, 11:30 AM
Registered Loser
Can you guys define what it means to drill out the separators. I'm looking at getting some new Magnacores but it sounds like they may have some fitment issues. Thanks
Current Rides:: 1987 Red 911 Targa, 2007 R320 CDI, 2003 Red Dodge Ram Hemi, 1993 Beater Jeep Cherokee, Airbus A320
Gone but not forgotten: 1981 VW Scirocco S, 1989 Honda Accord Coupe LXI, F-16C (still my favorite vehicle!),MC-130P, C-130E, T-38, T-37, C150, C172, PA180
Old 05-21-2011, 08:03 AM
KNS KNS is offline
The black plastic "holders" for the ignition wires are slightly too small for Magnecor wires. With the wires removed, use a drill bit to enlarge the holes that the wires run through.
Kurt
Old 05-21-2011, 02:07 PM
Arrow
No problem running without separators as the clewetts have thick shielding and the added heat sheathing. I have run mine with MSD components and no arcing or other issues.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 05-21-2011, 03:12 PM
