emac's Avatar
MSD Coil Question
Can I use a MSD Coil on my stock 81 SC without causing damage to my CDI unit. I do not have the MSD installed, I just want to use the coil.
Thanks in advance.
Ernie 81 SC
Old 05-28-2006, 04:04 AM
emac's Avatar
bump
Ernie 81 SC
Old 05-28-2006, 06:30 AM
Early_S_Man's Avatar
Porsche Crest
Ernie,
You can use the MSD High-Vibration epoxy-filled coil without fear. I wouldn't use any other MSD coil in the stock mounting location, as that could cause oil leakage and coil failure!
I have tested the MSD High-Vibration epoxy-filled coil for over 120 hours continuously on a test bench with Bosch and Permatune units under a heat lamp [to simulate underhood 200°F temps] ... identical output to the stock Bosch coil, and no problems!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-28-2006, 08:40 AM
just saw an add in Pano, May/06 p72
Says
"Perma-Tune is back bigger and better than ever under the original California management."
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-28-2006, 09:58 AM
emac's Avatar
Warren
Thanks for the info. That is what I have but when I put it on my tach jumped a few times and I thought there was too much voltage. I have been driving for the past two days without a problem and no tach issues. It seems to run much better with the MSD.
Ernie 81 SC
Old 05-28-2006, 10:07 AM
