MSD Coil Question
Can I use a MSD Coil on my stock 81 SC without causing damage to my CDI unit. I do not have the MSD installed, I just want to use the coil.
Thanks in advance.
----------------------------- Ernie 81 SC |
bump
Ernie,
You can use the MSD High-Vibration epoxy-filled coil without fear. I wouldn't use any other MSD coil in the stock mounting location, as that could cause oil leakage and coil failure! I have tested the MSD High-Vibration epoxy-filled coil for over 120 hours continuously on a test bench with Bosch and Permatune units under a heat lamp [to simulate underhood 200°F temps] ... identical output to the stock Bosch coil, and no problems!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
just saw an add in Pano, May/06 p72
Says "Perma-Tune is back bigger and better than ever under the original California management."
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Warren
Thanks for the info. That is what I have but when I put it on my tach jumped a few times and I thought there was too much voltage. I have been driving for the past two days without a problem and no tach issues. It seems to run much better with the MSD.
