Surging and jerking problem 84' 3.2L
To add this. It may be relevant:
The idle constantly fluctuates as well, not wildly but by maybe 200 rpm. Also, at the linkage if you barely increase the rpm and hold it, it bounces around. It also dose not rev smoothly through the first 300 or 400 rpm. Am I making any sense here.
Something is just not right here.Minimal throttle pressure just does not feel right on this car.
At a slight touch of the throttle the car surges. When cruising around 40 and while slightly touching the throttle it only does it enough that the driver would notice it. But when in heavy trafic at 5 to 10 miles per hour it make the car difficult to drive. It actually causes it to jerk quite badly. You really have to work the clutch to drive in heavy trafic.
Any suggestion, Thanks
Paul
84' Cab
77' 911s rebuilt 2.7
Old 11-04-2006, 07:11 AM
Jascha's Avatar
Not to worry -these are usually resolvable air (sometimes fuel) metering problems...
You can start here (if it was just idle another scheme is needed):
1. Air Flow Meter (AFM) is not recording correctly air flow values. There is a DIY way to refurbish it (search on my name for a similar thread)
2. Vacuum (false air) leak. One known offending area is from intake manifold gaskets –try to re-torque (16 -18 ft-lb !) the 12 bolts
3. Check all vacuum hoses / connectors to the throttle body...
1995 993 ('Under my Care')
1989 911 ('Go Pitt')
1996 993 ('Go Navy')
1984 911 ('Go Pelican')
Old 11-04-2006, 07:25 AM
Nine9six's Avatar
Yeah,
Do a search...Maybe the CHT sensor...
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 11-04-2006, 07:26 AM
Sports Purpose 911 Driver
mjshira's Avatar
sounds like CHT sensor. start there first. or DME fuel relay. both cheap to address.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 11-04-2006, 08:19 AM
Goth's Avatar
The 3.2 has a micro switch toward the back side of the throttle body. It should just click when the throttle is closed, and just click right as the throttle is cracked open. When this switch stays on past idle, you get the symptoms you described.
Doug
84 Carrera Coupe - Black (the Goth look)
The more I learn, the more I realize I don't know
Old 11-04-2006, 08:34 AM
I suggest doing a basic tune up/mixture adjustment first and if that takes care of it...you're done!
Old 11-04-2006, 12:34 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
+1
bad mixture can cause you to spend tons on a shotgun effort.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 11-04-2006, 01:58 PM
450knotOffice's Avatar
I wholeheartedly agree with stlrj. I had these same exact issues you describe and at times the car would be absolutely underivable. I checked ALL of my intake fasteners for tightness and found all of them to be tight except for the clamps that attach the AFM to the big rubber elbow that leads to the throttle body (I tightened the clamps). I also removed the Idle Control Valve and cleaned it. It was fine. Still no improvement. Finally, I brought my car to my Porsche mechanic and asked them to check and adjust the mixture and idle speed. They had to use a Gas Analyzer in order to properly set the idle mixture and then adjusted the idle speed properly. Later that day when I picked up the car from them the car ran perfectly They said the mixture and idle speed adjustments were both way off when they got it. They adjusted both parameters to spec and the car has run perfectly ever since, and I mean perfectly.
More than likely your idle mixture and speed settings are off. Have those adjusted properly and then if you still have a problem try checking other sensors.
Old 11-04-2006, 02:01 PM
911 in SC's Avatar
I have the same symptoms, but only AFTER I did a tune up (thanks for your help Dan and KC!!). I'm curious if there is something I could have 'hit' or 'bumped' while I was there that I was unaware of. I did notice that the PO had used Bosch WR-5-DC+ spark plugs, while I went with the Bosch WR7DC Spark Plugs that Pelican recommended. Could this have an effect?
If you guys think I should post this in a new topic, I certainly will...
Thanks,
Mike
Mike
'84 Grand Prix White RoW Carrera
Old 11-04-2006, 02:17 PM
Driving member
jester911's Avatar
Make sure you check all three plugs/sensors on the left side of the engine. CHT and flywheel sensors both can cause some of these symptoms.
You may have just bumped them and unplugged one just enough.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 11-04-2006, 02:23 PM
Certified Pre-Owned
BGCarrera32's Avatar
In a word, no. The WR7DC is the standard copper plug. Shouldn't be an issue if gapped correctly.
For the guy with the poorly idling engine, start with the simple stuff first. Make sure your oil fill cap is tight...
'84 Carrera Coupe
Old 11-04-2006, 04:29 PM
911 in SC's Avatar
I didn't think so, but am at a loss of why the PO had different plugs.
That's one 'variable' I can put to rest. Now to check all of the connections to the sensors and vacuum lines.
Mike
Old 11-05-2006, 06:19 AM
Thanks for responses
Thanks to all who responded. I think I will go the tune up route and try and check the whole system by using a manual.
PK
Old 11-05-2006, 10:36 PM
