newb.
capacities of '72 and 964 oil tanks? / Expansion of '72 tank...
Guys - anyone have nearby data on the relative capacities of the 1972 oil tank vs. the 964 tank?
Additionally, and perhaps more importantly, have any of you expanded the capacity of the 1972 tank? We are looking at doing that here in the shop, but wanted to probe the common (or uncommon) wisdom for the BTDT experiences... TIA!
keith '75 RS/RSR-look | '73 CB750 | '70 TD250B r gruppe #436 |
newb.
btt.
I would also like to know some info on this .... Since I am putting a 3.6 into my 72.
I am pretty sure the way to go is to enlarge the 72 tank VS the 964 tank . Thats what I think jack did on BB2. |
newb.
I would also like to know this!
Call Jerry woods inter. @408-369-9607
they use a vender that adds two QTs oil capacity to the stock tank, and they baffle it for $490. plus an additional 135. for ultasonic cleaning if you so desire |
Administrator
TRE Motorsports did exactly that for my car. It's a 1972 with a 964 motor, and they did a belt cut and expansion on the '72 tank to increase capacity by almost two quarts.
Unfortunately, I don't have any pictures of it. It might be a good idea to add some baffles at the same time.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
I don't think the Jerry Woods mod is for 72 tanks. You would have to do a custom mod. It looks to me like you couldn't make the tank much deeper or it would interfere with the torsion bars. Maybe Jack can shed some light on that problem. I use a stock 72 tank on a 3 litre motor with no problems. Others in my Toyo Spec group also use stock 72 tanks. The 72 seems to be better than the other year tanks because it tapers down at the bottom and leaves little room for oil to slosh away from the outlet.
I'm sure it would be better to have a bigger tank but you may find the stock 72 is good enough. I keep mine full to the anti-foam screen, this is about 1/2 quart over full on the dipstick. If your car runs slicks or big wings you may need a better tank to handle the G's. -Andy
72 Carrera RS replica, Spec 911 racer |
This info might be in the oil tank thread from a month or 2 ago.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
newb.
Andy - we were thinking similar - in terms of suspension interference.
Jack - would love some pictures, if possible! will search for that thread...
Fabcar did the oil tank expansion on my '73 RSR Clone. They welded in an extra section that lengthened the tank by about 2 inches and they added internal baffles.
My whole system hold something like 12-13 quarts now. Let me know if anyone wants a better pic of the modification. I'll have the car on the lift to put in the Pagid Orange pads for the DE at the Glen this week.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Yes, Please, I'd appreciate more detail on this mod..
Kind regards David |
Slightly off your topic keith....
Does a 3.6 in a 72 with twin oil coolers really need to have the oil tank mod. If I could get by like Andy suggested "over filling" that would be OK with me . Anybody know a sure answer? |
Here's some more pics of my RSR oil tank as modified by Fabcar. I believe Smart Racing does the same type of mod.
The tank has been lengthened by 2 inches and internal baffling has been added to eliminate oil starvation during hard braking and cornering.
Automotive Writer/DP
After that experience, I decided not to take any more chances. The motor that was built has a cross drilled crank and a '74 style Fabcar extended and baffled tank and GT3RS oil pump - no problems so far. The line leading from the tank to pump is now much larger and shorter and in the right direction.
1972 S - Early S Registry #187 1972 T/ST - R Gruppe #51 http://randywells.com http://randywells.com/blog |
Randy,
I've always thought the same thing (about the oil sloshing away from the pickup if its mounted fwd of the engine). But, all the big time 911 racecars I've seen use an oil tank in the smuglers box up front and they are definately on big-arse slicks. SMD
Stephen 70 914/6, GT clone, 3.0L 83 911SC, IROC clone, 3.32L, EFI 84 930, 3.5L |
