How to replace speedometer light bulb?
One of the 2 light bulbs on mine seems to have blown and I'd like to check/replace it.
I pulled the speedo but how do I remove the bulbs? Are they screwed in? Pressed in? or ??? Only thing I can tell is the one that doesn't seem to work is spring loaded - I tried to pull it and it spring back into position. thanks. |
Once you get the bulb socket out of the gage, just push the bulb in and rotate 90 degrees. The bulb will simply pull out after that.
oops - that was my problem. I couldn't get the socket out (its the 2 red ones).
Speedo Bulbs.....
Use a small bladed screwdriver or a pocket knife to ease the bulb holders from the speedo. Don't pull on the wires. You run the risk of having a bulb drop into the instrument. It is not easy to get them back out!
Good luck! |
Hi Fred,
Yes - did that (pulled the wire :( ) and I could hear the bulb bouncing in the speedo now... Does the bulb holder simply pulls out? |
Bulbs....
Yes, the bulb holders simply pull out. They are a "firm" fit so you will usually need to use a tool to get them started out.
What type of bulb and where do you get them?
I went to local dealer and they were about $5 each but the identical VW bulbs were $1.20.
Check out the LED upgrade available from a member in this site. Totally worth it.
I just went thought this. Here are the steps I used (with pics).
| All times are GMT -8. The time now is 11:00 PM. |
