'79 911SC Targa
Let There Be Light-Gauge Bulb Replacement
Recently I upgraded the bulbs in the gauges of my ‘79 Targa to LED bulbs. This is a simple project, but for guys like me who didn’t grow up around cars, some guidance and a few photos are always helpful.
The goal for me was to replace the gauge illumination bulbs, the bright lights indicator, and the running lights indicator. I did not replace the turn signal, oil pressure, or generator bulbs since LEDs are not advised in these locations. One more point to note is that I had to remove both my Momo steering wheel and the hub adapter to get the tachometer out. I would imagine that if you have a stock wheel it would be possible to get the tach out without removing the steering wheel, but it may still be a tight squeeze. All of the gauges are friction fit, meaning there is no hardware holding them in. It is a tight fit so you will need a good grip and a little twist motion but they will come out just by pulling on them. That said, I started with the clock and before putting it back in the hole, I reached in an pushed the speedometer from the back. I repeated this for each gauge and that made the whole process much much easier. Even with the steering wheel and hub adapter off, the tachometer was still difficult. It required some finesse and I had to push up with firm force on the dash’s eyebrow, but it did eventually come out. Steps for me were: 1) Remove the steering wheel and hub adapter and cover horn wire so it doesn’t short and scare the heck out of you. (Don’t forget to mark the spline before pulling the hub adapter off) 2) With a firm hold pull the clock bezel while giving a gentle twist PULL until it is out. 3) With a small screw driver, pry up the top ring of the bulb socket until you and grab it with your fingers. Illumination bulbs had black/blue wire for all gauges in my car. 4) Push in and twist the old bulb until it comes out. 5) Insert new bulb, quarter turn and ensure it is seated properly. 6) I turned the lights after each gauge to ensure the bulbs were seated and working. 7) Reach in and push out the next gauge before reinstalling the current one. 8) Repeat for each gauge 9) Reinstall steering wheel. I will admit that I had second thoughts on posting this because this is such a simple task. But it would have made me a bit easier before I started to have read something like this, so here it is. Before ![]() Speedometer ![]() ![]() Tach ![]() Oil Pressure and Generator ![]() After and what a difference!
Chief Head Scratcher
Nice write up! What kind of LED bulbs did you use? Any links to where you bought them?
John Morris '79 911SC |
I think thats great and I really appreciate the pics and description. Would you mind telling us what bulbs you used. This may be a weekend project for me right now, looks great, Thanks
+1! looks really good, this has been a project ive been putting off for some time now. perhaps this will give me the motivation i need!
- '78 911SC TARGA Dear Optimist, pessimist, and Realist.....While you were all argueing weather the glass is half full or half empty, I drank it. Sincerely, Opportunist |
'79 911SC Targa
Thank you for the positive feedback so far. I am happy that the post will be helpful.
I purchased the bulbs from Pelican member Etarga. You can get the full story in this thread: Ultimate LED. He offers several bulb choices so you can get the look you want. I went with the Ultra White and like them because they are bright and a good color temperature for me. In other words, they are good and white without any blue hue or tint to them. He is easy to work with and guarantees the bulbs for 2 years as well. May your flag be green... Last edited by FL911SC; 09-17-2013 at 02:28 PM.. |
fwiw, i have a momo steering wheel and adapter and am able to get the tach in and out without removing them. it's a very tight fit and requires pushing up on the dash, but doable on my car.
Nice !!!!
Bill MID9 #4 if i cant play with it ,,i dont want to own it Last edited by 911S Targa; 09-17-2013 at 01:20 PM.. |
Well done!!
1986 911 Targa We affirm that the world’s magnificence has been enriched by a new beauty: the beauty of speed. A racing car whose hood is adorned with great pipes, like serpents of explosive breath - a roaring car that seems to ride on grapeshot.... |
muck-raker
nice write-up, thanks!!! Looks great, too.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
registered woman user
that was any awesome write up. I have replaced all my bulbs with etarga LED's. but could not get the tach out past the hub. I'll give it another try this weekend. do you need to remove the center nut on the steering column to get the hub off?. thanks again.
white 1986 3.2 targa 911 life is what happens while your busy making other plans
Weekend Mechanic
I had to remove the steering wheel and plastic housing around the column to get the tech out.
86 911 Carrera Targa
'79 911SC Targa
Good luck with it. Last edited by FL911SC; 09-18-2013 at 08:10 AM.. |
Guido
http://www.carrera-32.com |
...and my blue mistress
Thanks for the write up. Glad you did it. Did the LEDs come with the bulb holders in your pics or were they the originals. Mine are a little, well... Mangled and/or missing due to a previous project that evolved into a "learning experience."
FS911SC
Thanks for the great instructions! I can't wait to install a set of LED lights I just ordered from ETarga. Since my car is primarily a weekend car, I don't find myself driving at night, but when I do I always tell myself that I should improve the dash/ gauge illumination. Next will be my headlights!
AJ 84 911 Targa, 76 911 Targa, 2014 Cayman S, 77 280z |
