Fractured stud
80 911SC
In the process of performing the stock exhaust system swap to SSI and M&K I broke the stud that holds the two large oil lines against the body. I have maybe 1/4 inch of the stud remaining. Q: How is the stud "fixed" into the body? ie > can I use another stud remover and try to unscrew the last bit out? Suggested remedy's??
Kim Langley 2012 Carrera / 991.1 80 911SC 97 C230 73 BMW 2002Tii |
Wer bremst verliert
you should be able to drill and "easy-out" that. Let it soak in PB Blaster or similar overnight and tap on it periodically/douse again.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
My guess?
I believe that the stud in the photo is a weld stud that cannot be removed by anything other than cutting off and rewelding/
Jeff |
