Mike Kunz's Avatar
Send a message via AIM to Mike Kunz
H5 to H4 Headlight conversion plug?
Hi,
Can someone tell me how the plug adaptor is used when converting from H5 to H4 headlamps? I ordered everything from Pelican and received two adaptors for the light connections, but am not sure if I am cutting off the existing plug or what to do with it...
Any clues?
Thanks,
Mike
VOPO '74 2.0
Old 03-26-2006, 03:06 PM
Mike Kunz's Avatar
plug pic
forgot to add this to my post...
VOPO '74 2.0
Old 03-26-2006, 03:08 PM
buttjoint's Avatar
cut and plug
Old 03-26-2006, 03:23 PM
A930Rocket's Avatar
I went through the same thing.
buttjoint is right. You have to cut your wires, but pay attention to where they go in relation to your old light.
After they are cut and stripped, you need to push up on side with the holes and insert the wire. Do the same fo reach. The side that has the holes is pushed on to your headlight.
Old 03-26-2006, 05:31 PM
Mike Kunz's Avatar
excellent...thanks guys!
Mike
VOPO '74 2.0
Old 03-26-2006, 06:12 PM
Pelican lists the plugs as no longer available. What is the alternative for the plugs to convert the headlights to h4 lights?
thanks
eric
1987 911 Cab
2002 Avalanche
2002 Saturn ugh
1990 Suzuki RMX 250
1985 Goldwing
Old 06-10-2006, 11:08 PM
KCPSG's Avatar
Go to Autozone or Pep boys (any parts store) and P/U a H4 plug end and wire it up...About $9.00 a plug IIRC
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 06-11-2006, 03:56 AM
Thanks! I will try the Marcus Sucro relay as well.
thanks
eric
1987 911 Cab
2002 Avalanche
2002 Saturn ugh
1990 Suzuki RMX 250
1985 Goldwing
Old 06-11-2006, 06:11 AM
KCPSG's Avatar
the Sucro kit is great...but you do understand that his kit is for running the higher voltage lights and has nothing to do w/the connection in the headlight bucket.
Phil
1998 BMW 328i
Old 06-11-2006, 07:20 AM
