Front Rotor
Trying to replace rotors on front wheels. According to service records this will be the first time. I changed rears with very little problem. Moved to front and cannot remove the dust cap. Any suggestions?
Stephanie
'86 911 Carrera Targa
Old 06-06-2006, 09:39 AM
ecm911's Avatar
911Gal,
May sound funny but use two hammers. Place the claw end of one against the dust cap and use the other to hammer the hammer end ot it.
got this trick from someone on this forum and it works everytime!!
Good luck!
Earl
78 SC Coupe
93 RSA (Gone)
Old 06-06-2006, 09:55 AM
Don Plumley's Avatar
There are many techniques for removing dust caps. I used a large drift punch angled from the inside of the car out (if that makes sense) on the outer ridge of the cap, hit it hard and kept rotating the rotor.
Don Plumley
M235i
Old 06-06-2006, 09:58 AM
B D B D is offline
B D's Avatar
The hammer technique works good sometimes it may need to go in a little before comming off. Keep going around the dust cap prying the cap up a little at a time.
68 911L
Old 06-06-2006, 10:08 AM
cycling has-been
bkreigsr's Avatar
the tech manual shows how to lay a bf screwdriver across the hub, then use that blade as a bottom for your lever, which is another bf screwdriver. work your way around the cap. use the hammer as little as possible
Bill K
Old 06-06-2006, 11:05 AM
Make Bruins Great Again
Por_sha911's Avatar
This was recently discussed. There is an excellent suggestion using a muffler clamp. Do a search.
Joe
Old 06-06-2006, 07:42 PM
Muffler clamp method worked beautifully for me!
Removal of Dust Cap on Frt wheels bearings
edit: not sure on the year range for which this method is appropriate!
Tom
'71 911 T Targa (Sold )
Old 06-06-2006, 08:06 PM
SP2 SP2 is online now
SP2's Avatar
I just used a ball peen hammer. Hit it at an angle, from in to out, and rotate the hub as you do it. It starts to easily wiggle out. Use some channel locks to pull it out, or I just used my hand. It's easy!
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 06-06-2006, 11:58 PM
the link from tswaney is the absolute bees knees....
simple...works....and no "hammering" around things like bearings that don't like this kind of rough treatment.....
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-07-2006, 05:46 PM
I just did this on a car that never had the dust caps off before. After much hammering, prying, and swearing on these milspec items I used the method in the link above and it worked like a charm. Get a 2" muffler clamp and a pry bar.
Old 06-08-2006, 08:21 AM
Still trying the clamp method. Nothing else works. This is probably the first time in 20 years this has been removed and it is definitely seized in place. Any other suggestions. Am I the only one with this many problems? My husband says I'm cursed. Beginning to think he's right.
Stephanie
Somatic Negative Optimist
Gunter's Avatar
I manage very well with large channel lock pliers: grab it perpendicular and wiggle up and down. Muffler clamp works great too.
These caps were off before for repacking grease, otherwise the bearings would have burned in 20 years without it.
Consider doing the whole front like bearings, rotors, caliper-rebuild.
That way you know that all is well up front.
The Bentley manual has a good write-up and pictures for the procedure.
Adjust the correct play in the taper-roller bearings with the split-nut (The one with the Allen bolt) according to the specs.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 06-08-2006, 09:02 AM
Thanks for all your help. For me the clamp and a 12" pry bar did the trick. After the cap came off everything else was easy.
Stephanie
Old 06-11-2006, 07:32 AM
