Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Can expandable Oil Return tubes be expanded too far?
First I want to thank everyone else here for thier threads concerning this topic. Without that information this would have been many levels of magnitude more painful.
I just finished replacing the aftmost oil return tubes (between cylinders 1&2 and 4&5).
Each was equally painful because I didn't want to remove the exhaust manifold. I'm a bit worried because the 4&5 tube expanded about a half mm further than the tube in the 1&2 did.
Here are my pictures:
New return tube between 1&2:
New return tube between 4&5 (the separation is a bit larger here:
Here's a the old tubes (thought someone might find it interesting to see them):
Sorry, the tubes on a pie box, which explains the carmel rings under and around the tubes.
So far I haven't had any leaks (I got her up to operating temp and turned her around so I could re-park her in my garage, no leaks while engine ran or after so far), but I'd like to know what some of you here think about it.
Should I be concerned, or is this normal?
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 06-09-2006, 11:33 PM
I don't think it is a concern.
I noticed some minor variation when installing mine.
No leaks so far!
Old 06-10-2006, 05:12 AM
MattAlpha's Avatar
Thanks, so far (about 10 hours after running the engine) its dry under my car.
This is the first time in since I got it.
Old 06-10-2006, 06:05 AM
