Kelly Bell's Avatar
A/C question
I have a 75 911S, and I am almost sure it has dealer installed A/C. The vents are bolted to the bottom of the dash, along with a tunnell of sorts, that carries the air to the vents.
Does anyone know if this is dealer installed? I strongly suspect so.
Kelly Bell
72 MGB
75 911S
00 Volvo S70
Old 06-13-2006, 06:10 AM
kuehl's Avatar
depends, you could have parts of this and parts of that,
most "dealer" units had a knee pad vent panel that had three louvers on the left of ash tray and three on the right, and the controls were mounted in the same knee pad vent panel adjacent the tray,,, call the Behr Knee Pad Vent (nothing to do with Behr paint, the other Behr)
now where are those pictures.....hmmmmm,
AH,,,, here is the link
http://www.pelicanparts.com/techarticles/mult_AC_faq/bez-inst.jpg
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 06-13-2006, 08:12 PM
Kelly Bell's Avatar
OK, Thanks. That is very similar to my car.
So, does a factory air car have the vents in the top of the dash? I ask b/c I am shopping for a plastic dash cover and they specify with air. I think I need one w/o air.
Kelly Bell
72 MGB
75 911S
00 Volvo S70
Old 06-14-2006, 01:24 AM
kuehl's Avatar
As I recall "Factory Air for 1978+" has the central ac vent in the dash above the radio and uses two small slotted vents on the left and right; however I have seen some 1977's with the same setup. "Factory Air for pre 78" cars had the Behr knee pad vent panel attached to the knee pad.
Old 06-14-2006, 04:52 AM
Kelly Bell's Avatar
Thanks!
Kelly Bell
72 MGB
75 911S
00 Volvo S70
Old 06-14-2006, 01:34 PM
