Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Smart Racing Front ARB Install
Quick question: on the SRP front anti roll bar install, how did you enlarge the stock "through the body" hole? Hole saw?
Thanks,
Michael
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 06-15-2006, 06:02 AM
With a hole saw and die grinder and a template made from thin sheet steel. It wasnt hard, but it took a bit of time as I was very careful not to over enlarge the hole and ensure a good fit.
What takes even more time is getting the mounts to line up perfectly side to side so there is no binding in the bar. Its a trial and error process with gentle bending of the mounts on either side using the bar itself as a lever. To get mine perfect on my '69 911S it took many hours.
Terry
Old 06-15-2006, 06:12 AM
Confused
I used a drill with a special drill bit - looks like a file on the side - great for enlaging the holes a bit as well - when you tighten the mount it changes it's alignment slightly.
I bolted the SRP mount to the fender well using the 3 existing nuts, scribed the holes and the centre holes, and went to work - took about 10 minutes per side to get the basic hole made.
What is harder to do is remove the 3 existing nuts on the inside of the fender well - used a small cold chisel and a ball peen hammer - and much cursing... have some ice handy for your fingers....
Centre hole was tidied up with a hand file and a power wire brush before painting.
I also had some interferance to the bigger sway bar itself from the fuel overflow pipe - removed the metal u-tube completely and replaced it with a flexible hose.
Squeaky brakes are safer....
2000 GT3 Clubsport, 1967 911 2.7 Track toy in progress
1983 Lamborghini Countach 5000S, 2009 VW Tuareg, 6 Bicycles - 3 Road, 3 Mountain
Old 06-15-2006, 07:48 AM
Rennch on YouTube
rennch's Avatar
Ok...I'm going to head down to our local "super" hardware store and see if I can find a good drill bit. Also...in terms of the holes being the correct size...isn't it ok if the body hole is a bit bigger? The plate bolts onto the car, and is perfectly sized for the bar, so I would assume it's cool to skip the body altogether.
And, in terms of the bolts, I thought the directions stated to leave the fixed bolts where they were for early cars, and thread the allen bolts into the existing holes. Then use nuts/bolts for the other three. I'll go back and re-read.
Michael O'Neal -
Old 06-15-2006, 08:19 AM
Rennch on YouTube
rennch's Avatar
Tspringer..
I can see what you mean about the binding. It's tough to get them right! I'm starting to devise a plan and going to get back out there again.
I had great luck enlarging the hole and using a rubber"stopper" grinder with a course sanding disc on it. Thanks for the help.
Michael O'Neal -
Old 06-15-2006, 01:56 PM
It helps to have the bar and bushings in place before you do the final tightening of the sway bar mounts. I've done 2 of these and the first one was really a challange to get the alignment right. If any criticism of the SM bars is the tolerances are too tight.
Old 06-15-2006, 07:45 PM
