Guest
Posts: n/a
Paint Color Codes
Does anyone have the paint color codes for a 70 911T. The plate with the color code on mine was damaged and I'm trying to identify the color code (and color name for that mater). It is an off white or light ivory color.
Guest
Posts: n/a
You can contact PCNA and send them the serial number of the car to get a "certificate of authenticity" and it will have the paint code/color that was the original color. I forget the cost, around $40 or so but they can tell you and it takes a month or so.
Guest
Posts: n/a
The Factory Maintenance Manual gives the following codes:
Light Ivory 1111 Ivory 4646 Gery White 7676 Those numbers are for a coupe, for Targas replace the last two digits with 10. |
Guest
Posts: n/a
Thanks Ken! That fits with what I can read on the damaged plate. The color must be Light Ivory 1111. I can now make out the number.
Guest
Posts: n/a
As I said in my previous post, the paint code plate now makes sense. One additional stamped letter on it is "-L-" right after the paint code. Does this just identify the type of finish, or does it have any other significance?
Guest
Posts: n/a
The Factory Book states that suffix L indicates the paint is from Lesonal. There is also a possibility of G - Glasurit and H - Herberts.
Guest
Posts: n/a
FYI,Optional color codes for 1970 were
Ivory 4610,Grey White 7610 , along with light ivory 1111.Paint mfrs are L-Lesonal,G-Glasurit,H-Herberts,HL-Herbol , according to Factory Tech manual. |
