Guest
Posts: n/a
DME problem
I have a '87 Carrera coupe. Recently, the car has a starting problem.
After inspected the other related components (fuel pump, fuel filter replaced, battery, alternator checked etc.) with my mechanic, we narrowed down to the DME unit. Interestingly, after a slight tap on the harness connector (a white bracket which connected to the DME unit under the driver's seat), the car starts again. The problem comes on and off for a month now and everytime it stuck, I just tap that connector and it starts. To me, something seems loosen inside. It is really annoying and I would like to fix it right a way. The car's stock torsion bars and sway bars were replaced with a stiffer one for autocross. Wonder if this modification caused the loosen connector. Any response would be greatly appreciated. Andy |
Guest
Posts: n/a
My methodology for electrical problems is similar.The techinical term is "percussive
maintainance". When this no longer works(or your knuckles start to bleed),it's time to clean the connectors.With luck this will do the job. After that it gets expensive. |
