Broken Clutch WTF!
My clutch decided to explode. The symptom was a dragging clutch, no matter the position of the pedal or how I adjusted the cable.
This is a new one to me. One of the 3 flat springs on the pressure plate broke. This is a Sachs powerclutch, about 1 year old. AL pressure plate. Here is the busted flat spring, or at least what remains: This is how it is supposed to look: It pounded my bell housing: It left a white haze on a variety of parts: I figure the haze was from the magnesium being pounded by the flat spring - either creating an aerosal, or perhaps actually burning the dust. All very strange. I figure the clutch should be covered under warranty. This seems like a material defect to me.
Chuck Moreland - elephantracing.com - vonnen.com |
Whoa - that looks pretty scary - being 1 year old I would have it back to the shop without doubt, good luck convincing them you werent drag racing
![]() Hope you get it sorted chuck and that the case isnt too damaged.
'89 3.2/3.6 coupe |
Warren Hall Student
Ouch! Looks like a rivet let go and the centrifical force threw the spring outward. I agree that clutch was defective from day one.
The white haze looks like burned magnesium. Magnesium is great at heat sinking like aluminum so it's rather hard to get large pieces to ignite but when it is chewed into small pieces it's very easy for it to ignite since the heat has no where to go. It leaves a white residue after it burns. I was working with magnesium once and had a pile of shavings on the ground so I decided to see if it would burn so I put a Mapp torch to it and it lit right up. Looked like I lit a sparkler and left the same white residue. There must have been a nice fireworks show going on in that bell housing.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Irrationally exuberant
Re: Broken Clutch WTF!
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Chuck,
I seen this failure many times with Sachs clutches. I curently have a 04 GT3 in my shop with the same failure and consequent trans damage. The GT3 had an uprated Sachs unit with very easy use. Good Luck with the warranty If you look at the Centerforce clutches for Porsche they are Sachs bodies with these very pieces replaced ( and higher rate diaphragm spring). We've had good luck with them in high hp cars.Dan J
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
Hmmm, I'd say Sachs owes you more than a prorated clutch.
Can you say callatoral damage and labor hours? Please post the net result, as this would certainly impact others decision on which clutch to purchase, should the need arise. Hopefully, Sachs would treat you fairly, do to your stature within the community, and your ablility to recommend/or not to others. Best of luck to you Chuck!
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) Last edited by Nine9six; 06-18-2006 at 07:47 AM.. |
The bellhousing looks pretty well reamed. Possible loss of integrity there or can it still be used with confidence?
Yes, it hammered the bellhousing pretty badly. However the meaty sections were the bolts secure the housing to the engine are still intact.
I've put it back together with a new clutch and I am going to give it try. I'll be monitoring the housing, inspecting for cracks regularly.
