86 911's Avatar
Send a message via AIM to 86 911
Lightbulb A tip for those of you re-building your Brakes
I just finished rebuilding my front calipers on my '76 911. In the process I found out that I have the aluminum "S" calipers (they run over $2700 per caliper new on Pelican ). Anyway, I got the rebuild kit and have been warned that the dust boot is hard to get on. I noticed that there is a circular metal clip inside the rubber dust boot that goes between the piston and the caliper. At first, I tried putting the boot in, but it gave me a hard time and felt like it was too big for the groove. Knowing that metal shrinks when cold, I put the dust boots in the freezer for half an hour, took them out, and inserted them into the groove. It was still a tight fit, but at least you could now push the dust boot in the groove with your thumbs! That's just my trick to it. It works pretty much for any other metal application.
Matt
'76 Porsche 911 with '78 3.0 SC engine
'71 VW Bus
'14 VW Passat (toddler hauler & wife approved ride)
'03 Subaru Baja original yellow & silver
Old 06-19-2006, 09:34 PM
Thanks Matt. For some reason I've never had a problem getting the dust boots in. But, if I do, I'll try your trick.
Marv Evans
'69 911E
Old 06-19-2006, 09:58 PM
vash's Avatar
that aint the only thing that shrinks in the cold. good job matt.
poof! gone
Old 06-20-2006, 07:51 AM
19 years and 17k posts...
azasadny's Avatar
Shrinkage! (Seinfeld reference)! Thanks for the pointer.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 06-20-2006, 08:24 AM
disband
juanbenae's Avatar
that ring you describe is to retain the dust boot. i dont know for sure in your case, but if i recall my rebuild kit came with new retainer rings. did yours? did you have the ring all the way out, install the dust boot, and then reinstall the frozen retainer?
i interpreted your post as trying to stuff the boot "flange" under the ring while in place. clearify...
Old 06-20-2006, 08:47 AM
lateapex911's Avatar
The flipside to the "Freeze technique is the heat method to expand stuff.
Some times you freeze one part while baking the other.
Slips in like butter, but won't budge once things equalize. An engineering buddy refers to that as a "Negative tolerance fit".
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 06-20-2006, 08:56 AM
vash's Avatar
toby, his calipers (s-caliper?) are different from ours. those are alot harder to do. my 75 had them, it was a cuss fest.
poof! gone
disband
juanbenae's Avatar
cliff, you dont seem like the type that would cuss at inanimimate objects. i only would expect beautiful songs to emanate from that pretty mouth of your.
T$
Old 06-20-2006, 09:01 AM
Dan in Pasadena's Avatar
Re: A tip for those of you re-building your Brakes
Originally posted by 86 911
I just finished rebuilding my front calipers on my '76 911. In the process I found out that I have the aluminum "S" calipers (they run over $2700 per caliper new on Pelican ).....
I have a '76S and my understanding is that I may or may not have the aluminum S calipers. Does anyone know the change over point or why some '76's do/don' have them?
I ask because I have rebuilt Carrera calipers for the front and have not installed them yet as discussed in another post.
I have not examined my calipers closely and I've heard there is a dimensional difference in the S and non S steel caliper mounting bolt holes. If I understand it correctly, 3" for one and 3-1/2" +/- for the other...not sure which?
I have been assuming I did NOT have aluminum S calipers since mine show some very minor surface rust about 1-1/2" square on the surface of the caliper body visible through the wheel openings. But maybe that is rust from metallic particles that came off pads in the past? Is it possible I DO have the S calipers (in which case I'll obviously stay with them!) Anyone?
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 06-20-2006, 09:11 AM
Zeke's Avatar
No such thing as S and steel S calipers. 3.5" steel cals are known as A. 3.0 are M. Then you go to Carrera cals (also at 3.5 spacing) which take a thicker rotor. Search bill Verburg's charts for further info.
AFA the rubber in the freezer, it might make it stiffer and easier to shove in the groove. It's been awhile, but I think the ring goes in after. Could be mistaken on that.
Old 06-20-2006, 09:51 AM
milt, I didn't write "steel S calipers" I wrote "non S steel calipers". I assumed everyone knew the early S calipers are aluminum, perhaps I presumed too much. I have since searched and realize the non S are cast iron, not truly steel.
My basic question is still: when/where was the cutoff point for the aluminum S calipers. Might I have them on my '76?
Dan in Pasadena
Old 06-20-2006, 10:06 AM
disband
juanbenae's Avatar
i think young mat's car is a 76 with a widebody kit, and 3.0L SC motor. so take that for what it's worth.
Old 06-20-2006, 10:11 AM
Toby,
Thanks but the kit and the 3.0 didn't come from the factory. At least the kit didn't. I suppose it could be a Carrera 3.o of that era...but I don't know enough to know if they came with the early S aluminum calipers or what? I suppose I should drop Bill Verbug a line. Thanks for he input, Dan
Dan in Pasadena
Old 06-20-2006, 10:14 AM
86 911's Avatar
Dan, the "S" calipers are aluminum and as a pelican told me, about a third of the weight of a steel caliper. The "S" calipers also have 3.5 inch spacing from bolt centers and come on cars built from '74 to '77. Your car may have them.
Matt
'71 VW Bus
Old 06-20-2006, 10:36 AM
randywebb's Avatar
can also use brake paste to lube these
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-20-2006, 12:12 PM
klaucke's Avatar
As far as I know (arguably not that much), only the Carrera's came w/ the aluminum S calipers. The 911 Normal and S from 74-77 came w/ cast iron M front (as stated above, 3" spacing) and cast iron M rear calipers. Matt's S calipers are probably an upgrade done to the car.
And as an aside, while the S calipers are light and valuable, the A caliper is dimensionally similar and actually has a better feel due to less flex. The S calipers are a good period correct upgrade for an early car, but there are definately better, or at least more cost effective, upgrades out there.
Old 06-20-2006, 12:24 PM
Thank you Klaucke. THAT is what I was trying to find out!
Dan in Pasadena
Old 06-20-2006, 12:34 PM
Zeke's Avatar
My '77 had aluminum calipers as ordered from the dealer by the PO. Koni struts too. That was the upgrade AFAIK. It was not a Carrera. It was a normal 2.7
Dan, thanks for righting me. I did indeed misread your words. The point is Bill Verburg has all this info. I believe the "S" AL caliper came in 2 casting designs (very slight difference) as I had both versions at one time. And the S caliper was made well into the late '70's according to what I know.
Old 06-20-2006, 01:13 PM
The early aluminum front caliper commonly referred to as "S" calipers were used on several models. All "S" cars from 69-74 had them. These were also fitted to E models with the comfort package and all Turbo Carrera 3.0 models. They were also fitted to most "S" cars and Carrera models from 1975-1977.
A freind even has an all original early Euro SC that also has these on it. I think it was a case of Porche using up what was left in inventory as the M caliper was phased in. Short answer is that there never seems to be a clear start and stop date for anything with Porsche's early models. That is part of their charm.
Old 06-20-2006, 01:48 PM
My 76S did not have them. FYI, the easiest test if you're unsure as to whether or not you have S calipers is to hold a magnet up to the calipers. If it sticks you're not an S man (or woman), but if it doesn't stick you are indeed in possession of the sometimes-coveted S calipers.
Old 06-20-2006, 03:11 PM
