Is this caliper toast?
Was trying to rebuild this caliper yesterday. Couldn't figure out why the piston wouldn't extend until we took off the boot and found this. We usually use a bike pump to blow out the piston but that method didn't work this time. Should I use a compressor or is the piston and caliper rusted beyond hope?
D idn't E arn I t
Does look like crap. I'd get it out wit air compressor, inspect the bores and try a mild sanding. Hopefully the piston isn't pitted out.
Amazing what salt air does to a car. rjp
In the movies only bad guys sleep in king size beds. |
May be wrong, but it looks like an A caliper to me. You should be able to find a decent one for cheap. Buying another one would make up the time you'd spend trying to make that one good, & this one might not turn out like you want it. Do the inside passages have a lot of rust also?
Marv Evans '69 911E |
Thanks Randy. I'll try the compressor next.
Yes Marv, the inside passages have rust as well. I'll ask around for a good, used, LH front A caliper if I can't blow out the piston and clean it up. New ones from Pelican are just a little under $300! Should calipers be replaced in pairs? |
Back in New England!
My opinion is to replace it with a new caliper (and the opposing caliper). That looks very painful, and in the end you probably will not be happy with the end result.
If your heart is set on rebuilding this one, I'd soak it in PB Blaster and let it sit half the day and then try expanding the cylinder. Good Luck and have fun with it!
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
Can I recommend cleaning or bead blasting it before you try and get the piston out? You want to minimize contamination of the bore and fluid passages.
-Brian |
Senior Member
Hey guys... using an air compressor can lead to the loss of fingers!
Rig up an adapter and pump the puppy full of grease. Yes I know its messy but it pushes out the pistons SLOWLY and lots safer. Then you can sit the caliper in some solvent and take a good look at it. To clean up the rust put it in a sand or beadblast cabinet. Looks like surface rust to me but you need to see how the bores look to tell. Joe A
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Agree with Joe, I'd be VERY careful getting that out with compressed air. I can guarantee it will sound like a cannon when it finally pops. Try not to be near it..
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2019 Tacoma |
I just did mine 2 days ago with an air compressor. I started with a small wooden handle and then used cardboard when popping the pistions out. Once the inner piston is almost out use the C-clamp method on the inner piston to hold it in place. Proceed to take the outer piston out. Once I got the outer piston out I plugged the hole with cardboard, held it tightly when using the air and it popped the inner piston out.
'94 VW Jetta '85 VW Scirocco '81 911 SC coupe Euro '67 VW Bug Last edited by Huh; 06-20-2006 at 11:10 AM.. |
D idn't E arn I t
Whatever you do, don't attempt to put your hand to catch it. It'll break fingers. That thing is screaming for a good soak in cleaner and glass beading. rjp
The easiest way of all to remove them is with them still on the car, with a helper operating the brake pedal. You can slowly push them out with hydraulic pressure. Use the same caution as with compressed air though. Propping wood in there is a good idea so they don't go flying.
-Brian |
Chris are those yours?
You can ask Doug about rebuilt calipers, I think he spent about $85 each? Drawing on old memories though, best to call him and ask him where he got them. I'll shoot you an email right now with his email addresses.... -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
Hilbilly Deluxe
For what it's worth, Kragen lists rebuilt calipers on their web site. As low as $51 for the front, and $43 for the rear, with a core charge.
If you want to be the gunea pig, print out the page and take it in with you. The register monkeys will try and charge you full price, up to twice as much as the internet price. Tom |
I dont recommend blasting or glass beading in or around the pistons, as you will want to only lightly polish or fine sand them. (Only a couple of tenths of a thousandth) to clean them up.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
On the blasting, I think he said to do it before removeing anything, thereby not getting any of the medium in the bores. Sounds reasonable. On the grease, it takes a fair amount of grease and even more solvent, then alcohol to get the things clean. I know it's safer, but......... |
Hilbilly Deluxe
Tom |
SCs had "A" calipers. For $51 I'd try them. The calipers are simple. Plus upgrading pads isn't expensive. You don't have to replace both calipers as long as the other one is working well. Like I said, forget that one. You're going to have to buy a kit, try to clean up the outside of that caliper, clean out the bore (which is hard to reach into), see if you can clean out the passages if they are really cruddy (& then you'll never be able to do a good job), and you're going to have to guy new pistons anyway. For me, it's a no-brainer. But, sometimes it's fun to resurrect something, if you have the time.
