jimi_c's Avatar
Replace or Repair broken Flag Mirror?
I need some advice. I had the passenger side mirror on my carrera kicked of by some friendly passerby and in doing so broke off one of the the metal tab at the base of the mirror. I have a replacement mirror that is primed and ready for paint, but my question is, would it be easier to paint and replace the entire mirror by removing the door panel, or can i disassemble both mirrors and just swap the base?
Cory H
85 Carrera
Old 06-21-2006, 10:43 AM
mschuep's Avatar
I'm a little confused but...
Either way you have to take off the base, and at least paint the new base right? If so, I would just swap the whole thing, it connects with a mirror motor harness connector... unless your paint is off-color or something, then I might consider keepin the old flag with the new base.
-Matt
1985 Targa
Old 06-21-2006, 12:46 PM
jimi_c's Avatar
The main difference is taking off the door panel and repainting. I'm not sure which is easier, pulling apart the mirror, or pulling apart the door panel.
Cory H
85 Carrera
Old 06-21-2006, 12:50 PM
mschuep's Avatar
the mirror disassembly doesn't look too hard...pm your email and I'll send you some info if you want to go that route
-Matt
1985 Targa
Old 06-21-2006, 01:01 PM
jimi_c's Avatar
PM sent, thanks!
Cory H
85 Carrera
Old 06-21-2006, 01:03 PM
I don't think you need to remove the door panel to remove the mirror.
There is an allen screw on the mirror that loosens the grip on the holes in the door. Check out how it works with your new mirror.
'69 911 Targa w/ 3.2
Old 06-21-2006, 01:34 PM
khamul02's Avatar
mirror removal and complete dissasembly is a piece of cake!
Once you disconnect the wires you will need a cheap 3/8 star socket
bit from Autozone or another crappy chain to unscrew the spring loaded bolt holding things together.
Take a peak at this thread:
Flag Mirror Help
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 06-21-2006, 08:06 PM
