Cutting air diverter for internal voltage regulator
I am in the process of changing the alternator on my '75 911S to the internally regulated Valeo unit sold by our host. In order to do this, the air diverter has to be notched so that the regulator will fit.
Does the portion where the regulator and diverter meet need to be tight, or can the hole/notch be a bit oversized? I ask this because I cut the notch in the diverter without allowing for the fan housing. This caused the notch to be a bit deeper than necessary.
Thanks for any help or suggestions.
Dane
'75 911S
Old 11-14-2012, 07:47 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Well, deed is done. Just monitor temps carefully for awhile to make sure it did not significantly diverted much need air flow over the cylinder heads.
Lucky we are headed towards winter, but spring and summer keep an eye on it.
My 2 cents,
j
FOr extra measure, make sure the top of the cylinders are free of debris. I recently opened my alternator for service and there were caked on dust/debris on top of the cylinders, I don't know how the #6 was cooling with all the debris.
'85 Carrera Targa
PCA/POC
Old 11-14-2012, 07:53 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Air diverter notch.
Dane
'75 911S
Dane,
When I replaced the VR on our '86, I had to cut a notch in the diverter
to accomodate the larger replacement VR.
As I recall, it was about 2" X 2".
I think you're OK, but post a pic for additional comments from other members.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-14-2012, 07:59 AM
DRACO A5OG's Avatar
Dr Gerry,
Which VR did you put in? I am planning to change mine due to wear.
Jim
'85 Carrera Targa
PCA/POC
Old 11-14-2012, 08:07 AM
pete3799's Avatar
Seriously doubt that will be a problem.
Pete
79 911SC RoW
Old 11-14-2012, 08:59 AM
