thaxtela's Avatar
Angry odometer not working
The odometer in my 1986 911 (turbo look) stopped working. I would like to have it fixed however am unsure if I should just buy the rebuild kit from Pelican Parts or attempt to find a used speedometer that does have a working odometer. I have no idea how "idiot proof" the rebuild process would be as I am new to this. The one I have is European and goes to 300 KM so I would prefer to keep it as I live in Canada. Any ideas????
Old 06-28-2006, 11:21 AM
Detached Member
Hugh R's Avatar
Without a doubt, send it to North Hollywood Speedometer. Do a search on odeometer and you'll get opinions both ways on D-I-Y NO ONE says its a piece of cake.
Hugh
Old 06-28-2006, 11:33 AM
heiliges blechle!
I did this repair... You cannot get the speedometer face off easily and it *looks* tampered with - at least from behind - when you are done. If you send it to get it fixed by pros then the bezel should look like new when you get it back. It is an ageing issue with the plastic gear so finding a unit with a working odometer (even new-old-stock) is not a good solution.
'84 M491 '07 Silverado
'75 Suzuki GT550 2-stroke triple
'02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train
Old 06-28-2006, 12:16 PM
Thrasher's Avatar
I agree with both Hugh and Bill.
I did this job and wrote a detailed posting with pix :
Odometer Gear replacement for Electronic Speedometers (long)
It is a tedious job and when the speedo is pulled, it is obvious that it has been opened. Also, I couldn't figure out how to calibrate my speedo while it was out. NHS could do it all very competently, but get your checkbook ready.
I'm a tightwad and felt like I'd really accomplished a major feat when mine was put back in and fixed for $25. It has clocked several thousand miles since then without issue. I got my gear from www.odometergears.com.
It looks perfect as it sits in-dash and works perfectly - just depends on your tolerance for tedium.
'84 Carrera Coupe - B&B Headers and one-out muffler; K&N Cone intake; Steve Wong Chip; Euro height and corner balanced; 171K Miles (9/12)
Old 06-28-2006, 12:28 PM
bigchillcar's Avatar
yeah..i believe the replacement gear will be brass and not the old plastic gear, which basically dissolves..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 06-28-2006, 02:14 PM
Thrasher's Avatar
mine was nylon. the rumour was that the factory gear was
1. lubed with an oil that caused it to dissolve
2. sacrificial and, therefore, made to give way before the other gears.
Old 06-28-2006, 02:17 PM
nylon..you're correct..i hadn't thought about this gear in a while. and you're right about the oil being the known culprit, too. you're batting 1.000, thrasher..
ryan
Old 06-28-2006, 02:20 PM
Thrasher's Avatar
Gotta be the 'roids.
I think the older cars had a pot metal gear in there that was also designed to be the sacrificial lamb (softer) so that if the works got jammed up, only the gear would give way, leaving the mechanism repairable.
Oh, and btw, there is also a wive's tail about the reset while moving causing this. It may hasten things, but only on a gear that's already well on its way to death.
Old 06-29-2006, 07:46 AM
yeah..always heard not to hit the reset button while moving as well..
ryan
Old 06-29-2006, 07:52 AM
Somatic Negative Optimist
Gunter's Avatar
ryan
That is one of those stupid myths that just doesn't die.
You can hit the reset button all day long while moving without any damage to the gears.
If you ever see the inside, and the mechanism, you'll see why.
If you don't believe me, send an E-mail to NHS and ask them about this issue.
Cheers.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 06-29-2006, 08:17 AM
okay doc gunt, i will buy your story and discontinue propagating the myth.. information is king and 'in the kingdom of the blind, the one-eyed man is king..'
ryan
Old 06-29-2006, 08:34 AM
IROC's Avatar
I have a 180-mph mechanical speedometer laying on a shelf that has this odometer gear failure. I would like to get it fixed as I suspect this speedo is somewhat valuable. What's the ballpark $ for getting NHS to fix this?
TIA.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 06-29-2006, 09:09 AM
steve911's Avatar
thaxtela--
Just had the same issue with my '85. Both the odometer and trip odometer stopped working. I sent the speedo off to NHS and had it back in less than a week. Cost was $130 + shipping. I had read the posts about doing myself and opted to let the pros have at it. Couldn't be happier.
Gauge looks great (they cleaned it in the process).
When you remove the gauge, carefully note where all the wires go. I labeled the wires and drew a diagram.
There are 3 lights in the back of the speedo as well. The entire housing comes out (with the bulbs) - just pry the housing out with a small screwdriver.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 06-29-2006, 09:50 AM
Thrasher's Avatar
Steve911, did that include speedo calibration?
Old 06-29-2006, 10:32 AM
steve911's Avatar
Yes, NHS calibrated it to factory specs
RIP Warren
Old 06-29-2006, 08:02 PM
Thrasher's Avatar
"Factory Specs" - so it's off by 5 mph like all the rest?
Old 06-30-2006, 08:20 AM
heiliges blechle!
I *calibrated* mine by installing the needle pointed at 0 mph. Then had a friend bring his GPS on a ride and it was only off by 2 or 3 mph.
Old 06-30-2006, 08:56 AM
I just had this failure as did a friend of mine. I was feeling adventurous tonight (a little liquid courage ) so I took her apart - it went real smooth.
My gear is toast just like the rest of them, so I ordered one from the link provided above. Should have it in a couple days.
I hope all goes back together as easily as it came apart!!
Brendon
80 911SC "Weissach"
77 930 (in pieces)
Old 08-10-2006, 07:10 PM
ewave's Avatar
Some info from my speedo rebuild, and trying to cal:
Carrera VDO Speedo SUCKS.
Paul
2001 CLK55 AMG, 1987 911 Turbo Look, 1997 Viper GTS.
Old 08-11-2006, 04:02 AM
TroyGT's Avatar
I replaced my odometer gear on my 86 Carrera and it wasn't so bad... least I could pull the gauge and bring it inside and work at the kitchen table, as opposed to laying on my back under the car. When I opened mine up, the gear was total crystalized. It just went all to pieces when I touched it. I ordered the gear, nylon, for about 20 or 30 bucks and replaced it myself. Not a bad job at all. You will have to work the bezel a little to get it off, but if you take your time and go slow, you can do this without mangling it.
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler,
Steve Wong Performance Chip
2001 Boxster 2.7L (Orient Red), bone stock
Old 08-11-2006, 07:18 AM
