Kantry Member
"About 7 years ago I installed the collars just to be safe. So far, no problems (though for all I know the collars have fallen off!). I guess if a tensioner did fail, I wouldn't know about it, because the collar would be holding it up. Kind of begs the question about the purpose of the tensioners to begin with, as I know you can buy a "solid" tensioner that doesn't move, and keeps the chain taught."
DDD, If your tensioner failed, the collar would keep the chain from junping the sprokets, but it would sound like someone was dragging a length of chain through a paint can. A sound which can really ruin your day. Solid tensioners don't 'give' at all, so they result in faster chain wear. No such thing as a 'free lunch'. ![]() Les
Best Les My train of thought has been replaced by a bumper car. |
Les: Thanks for the reply. I've always wondered about the solid tensioner -- they are described as good for "racing" which I guess means good for people that are always tearing down and rebuilding their engines, since they are probably replacing the chain often.
Your comment on how the collars work gives me much peace of mind, since I don't hear the noise you described. Thanks again. --DDD
1983 Ruby Red Metallic 911SC 2005.5 Audi A4 2.0T Quattro 1991 Mazda Miata Special Edition British Racing Green www.DDDinMN.wordpress.com |
Holy @%$#$&^*&!!!11 I've getting some pulsation between 2k and 3k lately and was about to check out fuel and ignition... It's there both on and off power, was that your case? I take back my comments
83 911SC Targa Everything I say is my personal opinion, and has nothing to do with my team. |
I'm with Bill
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Either way, I guess it's time for the inspection that I've been putting off.
I agree with the "drive it home" theory. If there are no terrible noises it is likely that your tensioners are working and will continue to work for at least the drive home.
My mechanical tensioners are original and I've bought the carrera tensioners - just need to find time to put them in. Cross your fingers and don't boot it.
Danno _______________ 1978 911SC Targa "Is this the new blues mobile - or what?" |
