| Brando |
				oil temp issue solved?
			I have had a problem with my oil temp since getting it put back on the road after being stolen. I just couldn't figure why my temps are so damn hot(9:00 to 9:30 posistion on the gauge) I have a 79sc and never had any problems before, but then it was stolen and made to be ghetto fabulous. In the "conversion" I guess they maynot have had the correct jacking methods at their disposal and I have some bug dents around the jack plate receptable. I also have a big dent where the line goes up into the front fender. My guess is that the oil isn't moving fast enough to do much good in the trombone? I found this checking for fitment of a new mocal cooler I got. The tire was out of the way and this is the best oppertunity to check things out since the issue was noticed. Am I at the end of my quest for the issue? I feel this is got to be the (expensive) reason. Any thoughts? Thanks
				__________________ Turbo powa! 1977 911s. it's cool | ||
|  06-28-2006, 10:34 AM |
| Brando |
			Has anyone repaired these lines? I assume you can sweat brass and copper with brass rods? Looks easy I guess after removing and cleaning.
|  06-28-2006, 11:33 AM |
| Registered |
			same thing i was thinking. i don't know for sure, but i'm sure someone like chuck moreland of elephant racing who sells lines, coolers, etc. could answer your question.. ryan
				__________________ To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) | ||
|  06-28-2006, 01:12 PM |
| Brando |
			Thanks chill, I tested a couple copper pipes with brass rod and it stands up to the added heat. I'll be doing a repair in the next couple days. I'll keep posted.
|  06-28-2006, 01:26 PM |
| Brando |
				pics
			Here are some shots of the lines that are damaged. What do you think?
|  06-29-2006, 10:47 PM |
| Registered |
			Your insurance should replace those lines (after theft damage).  They are terrible.  No wonder you are hot.
				__________________ 74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender | ||
|  06-29-2006, 11:32 PM |
| Brando |
			I didn't claim anything so it doesn't have a bad title. The car is great other than this, infact this is the only damage I have, other than the fact he painted everything incl;uding rubber and the roll bar  Plus, he took my fuchs I fixed everything back to rightious.
|  06-30-2006, 07:15 AM |
