Jeep Cherokee Cap and Rotor on a 3.2
This conversion allows the use of conventional HEI ignition wires without the need of modifying the cap connectors or boots to fit a Beru cap.
Joe
Delayed post 10/24/06:
I'm not sure how to do that set-up for myself, but it looks like it's worth doing.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Lot easier than twin plugging. It just takes a little time and ingenuity.
Joe |
It may work great, but it looks like something that Macguyver did.
The jbwelded rotors and the stacked caps, I just don't know. I read your thread about running with a .060 gap. I didn't think that my old 3.2 really ran that bad that it needed the little boost.
"O"man(are we in trouble)
I think I'll stick with the original design, thanks. Looks less expensive in the long run.
The British Royal Family had an infusion of German Blood in 1714 with Hanoverian King George. Later, Chrysler bought Daimler but Daimler really bought Chrysler. And now this.
'66 911 #304065 Irischgruen 96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Virginia Rocks!
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
stlrj , did you get a full two driving seasons out of this set up? How well did it hold up? What other changes/improvements are in the works?
If Porsche thought like these guys we would still be driving rear engined air-cooled cars. Oh wait a minute.............................
Just a differnt way of looking at it...and considering the cost, a worthy ignition upgrade before taking more complicated routes. Cheers, Joe Last edited by stlrj; 10-25-2006 at 08:45 AM.. |
Cheers, Joe |
I argree with Noah....
twin plugging gets around the problem ( among other things)...like domed pistons that cut into the flame front...and how two plugs on either side of the "split dome" will work, ....while a "bigger" offset-located spark won't.... - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Cheers, Joe |
But put that same 0.060" plug gap in an engine designed for a single plug, now you have the benefits of better more complete combustion and driveabilty including low end response. Cheers, Joe Last edited by stlrj; 10-25-2006 at 01:13 PM.. |
Driving member
So your saying your driveability is enhanced with this setup.
Interesting.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. Last edited by jester911; 10-25-2006 at 03:45 PM.. |
Slippery Slope Victim
How about using a MSD set up? I have been playing around with spark gaps on my hot rod 3.0 and have used a .060 gap with no problem.
MikeČ 1985 M491 |
Yes, but a Ty-Rap is so much less expensive.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Wouldn't it be fun to be out in the desert when the tie-wrap or JB Weld decides to let go? NOT!
Good idea....but in my book WAY to risky.
1984 Targa |
There is some merit here. I found a gut who does all kinds of distributor conversions. I have one that incorporates a Ford module in a small diameter small block Chevy dizzy. That's one of his specialties. When talking to him about my 914 engine a few years ago, he immediately thought a Pontiac Tempest Cap and rotor could be adapted rather easily with a small amount of work on the lathe. I've also read about Jag V12 caps for the twin plug single dizzys. Seems to me the thought is good even if the execution is somewhat jackleg. But, that's how things get tested.
Now, go make a proper adaptor. You might have something then. |
Virginia Rocks!
I'm still not clear on how it allows you to make a bigger spark? I'm assuming that the cap terminals are approximately the same size and you didn't really do anything to the igniition system to make a bigg spare go through the distrib, so I just don't get why it works. Did you have to upgrade to magnacores to handle the extra power however you produced it? I'm not poo pooing your idea, I just don't understand it.
Yes, he uses different wires, from a Chrysler actually.
