tiim
Guest
Posts: n/a
SC hot start problem
I've read all the postings here about start-up problems, but none seem to be similar to what I'm currently experiencing. When the engine is good and hot (between the two middle marks on the temp gauge), then shut off, it refuses to start again. It _feels_ like the battery has no juice: the engine barely turns over once then stops. My mechanic has checked the entire charging system and everything seems sound. Once the engine cools, everything is fine. Any ideas? (82 SC)
Old 10-22-1999, 09:09 PM
Lee Wister
Guest
Posts: n/a
You need to have your mechanic do a voltage drop test to the starter. This test will tell wether it is a poor ground curcuit or starter.
Good Luck,
Lee
Old 10-23-1999, 09:26 AM
