Drew
Guest
Posts: n/a
how do you adjust the idle on an SC
Can't seem to figure out how to adjust the idle speed on my 79 SC. Is it the large sloted scew with spring on left side of throtle body?
Drew
Old 10-23-1999, 01:12 PM
Hence
Guest
Posts: n/a
Yes.
Old 10-25-1999, 10:46 AM
Gonzo
Guest
Posts: n/a
So if you turn it clock wise does that increase or decrease your idle?
Old 10-26-1999, 01:04 PM
Hence
Guest
Posts: n/a
I don't know, but the easy way is to try it and see! But, to take an educated guess, I would think that if you turn the screw clockwise, you would be "tightening" it (assuming that it is standard threaded, which I'm pretty sure it is), which would reduce airflow, lowering the idle. Turning it out (i.e. counterclockwise) should increase idle.
Brian
Old 10-26-1999, 04:21 PM
Drew
Guest
Posts: n/a
In (clockwise) does reduce the speed.
thanks
Drew
Old 10-26-1999, 07:51 PM
