As i stated in my first post, the WUR i am using came from a 1978 Porsche 928. (model# 0-438-140-053) I have since set the proper control pressures and reset the mixture (since the higher control pressures create a lean mixture) The cold start problems have now dissapeared and the car runs great throughout the whole temperature band.
I only have one more problem to solve. If i really mash the pedal, the car still runs lean and backfires. I would assume i am having vacuum enrichment problems, but since i dont have a vacuum tester, i cant validate that for sure. Since i am using an unfamiliar WUR, i know that Bosch switched the enrichment ports (top and side) on varying models of WURs. Is there any way to figure out which port is the vacuum enrichment port?
'78 Euro 911SC (Ongoing Project)
'83 911 Fashion Grey Outlaw
Old 08-06-2006, 05:02 PM
