| Registered |
				RSR 3.0 Piston/Cyls.. worth buying used?
			Hi, I was searching ebay in germany and found a set of used P/C's for RSR 3.0 complete set + 4 extra pistons what kind of problems would you usualy find on these, I mean.. what would be worst case for buying used cylinders unseen.. out of shape with piston slap? if so.. I can get cheaper paperweights locally!  (there are som pix in the auction) Perhaps someone else has a need for a set, seems to be out of stock in most all parts houses as well!? disclaimer: I have no connection to this seller.. just stumbled across these.
				__________________ "old cars and bikes" == System architect & developer | ||
|  07-06-2006, 10:21 AM |
| Registered Join Date: Aug 2002 Location: Galivants Ferry, SC
			Why not "certify" all the critical dimensions.....diameter measured at 90 degree intervals....ring and land height/depth, etc.....get it measured and written down as "certified correct" and use it a warranty/ gaurantee for the sale? - Wil
				__________________ Wil Ferch 85 Carrera ( gone, but not forgotten ) | ||
|  07-06-2006, 10:37 AM |
| Registered |
				careful buying used p/c
			Wil is right. Make sure both the p & c are within spec. I once used a used set out of spec in a rebuild. Burned so much oil you had to change the plugs every 200 miles. What a waste of my time!
				__________________ 77 911, 3.0L | ||
|  07-06-2006, 10:49 AM |
