07 Audi A4 2.0T Cabriolet - Black/Black (sold) 96 993 C2 Cabriolet - Arena Red/Tan (sold) 82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold) 58 DKW Universal - Baby Crap Yellow/Beige (sold) Last edited by mppickett; 07-06-2006 at 07:52 PM.. |
It really depends on how much boost your gonna run.....I would say
425HP at the crank. Last edited by herman maire; 07-06-2006 at 07:58 PM.. |
I'm shooting for 1 bar boost in 3rd gear.
07 Audi A4 2.0T Cabriolet - Black/Black (sold) 96 993 C2 Cabriolet - Arena Red/Tan (sold) 82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold) 58 DKW Universal - Baby Crap Yellow/Beige (sold) |
I look forward to seeing how long the trans lasts.
I would like to keep my 915 in my future 3.6 turbo in my 72 but I keep hearing it will blow. Hope she holds. |
I agree. I really like the 915. I'm actually pretty easy on the trans in terms of shock (I don't drop the clutch or power shift). I do think the torque is going to catch up with it sooner or later, though. Rarlyl8 has had pretty good luck with his if I'm not mistaken.
my guess at 15lbs is 417 hp , now to get nitpicky are the numbers gonna be sae corrected hp or observed??
I was going to report SAE corrected numbers for the purpose of the contest. Elevation of the dyno is around 350 above sea level and the temperature tomorrow should be in the low 80's. The weather is supposed to be partly cloudy. I suspect that there won't be much difference between SAE corrected and raw DynoJet numbers.
My guess is 395 hp
427 hp
403 ft-lbs I'll take the stock wastegate spring. ![]() -Rod
'88 930 Cab |
Oh, I know, I know, Oh Oh
...Very similar setup from mine except you got the EFI goodies and twin plug. Since mine on a DynoJet 249C got 403 RWHP/390 RW Torque, I say you should be somewhere around 440.233 RWHP and 440.245 RW torque +- .001 During my dyno run, I filled my tank with VP MS109 just to be safe Make sure you have a big a** fan blowing in the back and maybe put a big cardboard tilted 45 degree deflecting air down to the IC.
David Nguyen 1987 930: 2700 lbs, 408 RWHP/405 RWTQ 930 pics: http://alturl.com/899f9 930 Engine rebuild pics: http://alturl.com/25qcy Last edited by porschett; 07-06-2006 at 10:10 PM.. |
PS is a measure of Power used in Germany for awhile...
No OCF for me this year and I hope that is not the same Marianne who has an office next to mine... Since you didn't like the PS units I will change my guess (estimate) to -- let's see now -- 73980.35 calories/sec. And if you don't like that one, then how about... 3.0959 * 10^12 ergs/sec ?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
My guess is between 350 and 375 for hp at the wheels.
DP935 member
415hp is my guess.
392 torque.
Porsche Slantnose M505 M506 group on Facebook. https://www.facebook.com/groups/719995181372494/ |
Where are you located Mike? And where are you getting the dyno tuning done?
Good luck! I'm in Concord. Just wondering how far away you are... Brian
Brian Keith Smith |
Hi Brian,
I'm over in Durham. I usually use Jeff Creech over at Carolina Auto Masters for dyno work. He's a Corvette guy but he's really good to work with
Wider is Better
427.5 ft-lbs of torgue with 432.5 HP
Wider is Better |
389 bhp. With other words, around 354hp at wheels.
Thank you for your time, |
1 bar boost and 50 lbs injectors will be the limiting factor here......I'm gonna say 460 rwhp with around 425 lbs/ft of torque.
If using a DynoJet 248C, I'll say 445 RWHP and 420 RWTQ.
Brian 1981 930 |
