mppickett's Avatar
Originally posted by Facey
488.4RWHP
465lb-ft
what muffler are u running...i could have just missed it...anyways my guess assumes a good free flowing muffler....
I don't know the muffler (here's a pic below in case someone else does). It is totally open inside - I think the previous owner gutted it. It doesn't do much muffling and I suspect backpressure isn't an issue.
07 Audi A4 2.0T Cabriolet - Black/Black (sold)
96 993 C2 Cabriolet - Arena Red/Tan (sold)
82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold)
58 DKW Universal - Baby Crap Yellow/Beige (sold)
Old 07-06-2006, 07:45 PM
It really depends on how much boost your gonna run.....I would say
425HP at the crank.
Old 07-06-2006, 07:51 PM
mppickett's Avatar
I'm shooting for 1 bar boost in 3rd gear.
Old 07-06-2006, 08:03 PM
I look forward to seeing how long the trans lasts.
I would like to keep my 915 in my future 3.6 turbo in my 72 but I keep hearing it will blow.
Hope she holds.
Old 07-06-2006, 08:09 PM
mppickett's Avatar
I agree. I really like the 915. I'm actually pretty easy on the trans in terms of shock (I don't drop the clutch or power shift). I do think the torque is going to catch up with it sooner or later, though. Rarlyl8 has had pretty good luck with his if I'm not mistaken.
Old 07-06-2006, 08:22 PM
my guess at 15lbs is 417 hp , now to get nitpicky are the numbers gonna be sae corrected hp or observed??
Old 07-06-2006, 08:47 PM
mppickett's Avatar
I was going to report SAE corrected numbers for the purpose of the contest. Elevation of the dyno is around 350 above sea level and the temperature tomorrow should be in the low 80's. The weather is supposed to be partly cloudy. I suspect that there won't be much difference between SAE corrected and raw DynoJet numbers.
Old 07-06-2006, 09:00 PM
My guess is 395 hp
Old 07-06-2006, 09:57 PM
427 hp
403 ft-lbs
I'll take the stock wastegate spring.
-Rod
'88 930 Cab
Old 07-06-2006, 10:01 PM
porschett's Avatar
Oh, I know, I know, Oh Oh ...
Very similar setup from mine except you got the EFI goodies and twin plug. Since mine on a DynoJet 249C got 403 RWHP/390 RW Torque, I say you should be somewhere around 440.233 RWHP and 440.245 RW torque +- .001
During my dyno run, I filled my tank with VP MS109 just to be safe
Make sure you have a big a** fan blowing in the back and maybe put a big cardboard tilted 45 degree deflecting air down to the IC.
David Nguyen
1987 930: 2700 lbs, 408 RWHP/405 RWTQ
930 pics: http://alturl.com/899f9
930 Engine rebuild pics: http://alturl.com/25qcy
Old 07-06-2006, 10:02 PM
randywebb's Avatar
PS is a measure of Power used in Germany for awhile...
No OCF for me this year and I hope that is not the same Marianne who has an office next to mine...
Since you didn't like the PS units I will change my guess (estimate) to -- let's see now --
73980.35 calories/sec.
And if you don't like that one, then how about...
3.0959 * 10^12 ergs/sec ?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
My guess is between 350 and 375 for hp at the wheels.
Old 07-06-2006, 10:33 PM
DP935 member
kycarguy 935's Avatar
415hp is my guess.
392 torque.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 07-06-2006, 10:36 PM
mppickett's Avatar
I accept your 73980.35 calories/sec estimate (just slightly higher than my own estimate). Not the same Marianne. I followed mine out there when she went to UofO and then followed her back to NC. Eugene was a great place to live and you have all of those nice mountain roads close by.
Old 07-07-2006, 05:28 AM
Where are you located Mike? And where are you getting the dyno tuning done?
Good luck!
I'm in Concord.
Just wondering how far away you are...
Brian
Brian Keith Smith
Old 07-07-2006, 06:32 AM
mppickett's Avatar
Hi Brian,
I'm over in Durham. I usually use Jeff Creech over at Carolina Auto Masters for dyno work. He's a Corvette guy but he's really good to work with
Old 07-07-2006, 07:14 AM
Wider is Better
wholberg's Avatar
427.5 ft-lbs of torgue with 432.5 HP
Wider is Better
Old 07-07-2006, 07:22 AM
beepbeep's Avatar
389 bhp. With other words, around 354hp at wheels.
Thank you for your time,
Old 07-07-2006, 08:02 AM
1 bar boost and 50 lbs injectors will be the limiting factor here......I'm gonna say 460 rwhp with around 425 lbs/ft of torque.
Old 07-07-2006, 12:09 PM
81 930's Avatar
If using a DynoJet 248C, I'll say 445 RWHP and 420 RWTQ.
Brian
1981 930
Old 07-07-2006, 12:17 PM
