Think yer a tuner? Predict the dyno result!
So here's the challenge... I'm going to spend Friday afternoon at the dyno shop with my newly rebuilt 82 SC with a 930 engine. Guess what the peak rear wheel horsepower and torque levels we'll see. Winner gets a choice of prizes:
1) totally stock 930 wastegate spring (~.8 bar) or 2) rear window defroster relay (I've got a cabriolet:) ) Winner must claim prize within 200 years of contest ending. Shipping not included. Employees of Carolina AutoMasters Dyno shop not eligible for contest. Batteries extra. Some information to guide your guesses: - Dynojet dyno - 1978 3.3 930 engine - reused the 930 pistons and cylinders - an Ollie's line-bored shuffle-pinned case - ARP head studs and rod bolts - twin-plugged, ported, polished & flowed heads - full balancing - 8:1 compression ratio - 964 cams - 3.2 Carrera intake - 50# fuel injectors (attention junior tuners, this is the wild card) - single Bosch front mounted fuel pump (unknown fuel pressure) - K27-7200 turbo - GoingSuperFast full-bay intercooler - B&B headers - twin EDIS-6 ignition controllers and coil packs - NGK Iridium spark plugs (BKR7EIX) - Megasquirt II v 3.0 ECU controlling fuel and spark - front fender mounted 36 row oil cooler w/fan - 1 bar peak boost in third gear - straight-thru muffler - 3" outlet - 915 transmission - cool collar (ok, I made that part up just to see if you're still with me) I'm scheduled for 2:00 pm tomorrow and assuming "bad things" don't happen, I'll post the results tomorrow night. You have until then to enter the contest. Let the games begin! http://pickettweb.com/icon/burnout.gif |
First off I think you're going to need more cooling...
My guess on the Dynojet you'll be at 375 at the rear wheels. |
I say 400RWHP. BTW, with your EDIS setup, how did you fit the 36-1 tooth wheel on your setup?
Nice setup! I don't consider myself a turner, but I'll pull some numbers out of the hat... 450 at the wheel? Probably low balled it. Good luck at the dyno.
405 rwhp
387.2 peak hp at 6500rpm
362.0 peak torque at 3275rpm Is this like the Price is Right - highest without going over? Nice spec sheet. |
350
Do you say the size of the motor? Is it a 3.3L. And what dyno are you running it on. It makes a hugh diff.
Woops Dynojet. Man I wish I could read.
I am going to guess 420 RWHP |
465 rwhp...
268 PS
1fastredsc - Mike, for the EDIS trigger I picked up the pulley with the VR wheel from Albert at goingsuperfast. Here's a pic:
http://pickettweb.com/Porsche/pulley.jpg Brendon, let's not use the Price is Right rules, closest wins whether you're above or below. As you can tell, this is just for fun. Anyone can race dyno sheets but it takes real guts to win at the track;) And just so you know, since I'm more of a wrench type and the car is a cabriolet, I race dyno sheets :D Randywebb, have you been out partaking at the Country Fair? What the heck is 268 PS? By the way, Marianne and I once saw the Flying Karamozov Brothers lead a totally nude marching band out of the Grove at the Country Fair (early 80's - no joke). Come to think of it, that was the last time I saw a totally nude marching band... Here's another pic to help increase the accuracy of folks guesses (the Speed Yellow paint is worth at least 2.7 horsepower and 4 ft/lbs of torque, right?). http://pickettweb.com/Porsche/final025.jpg |
409rwhp.
Your going to need a new trans soon. |
Just to give you an idea.
http://media.ams-evo8.com/videos/amsmisc/PorscheDynoRun.wmv This is @ 16 psi but the intercooler was heatsoaked so I lost about 10-15rwhp |
389 and within a year you will need a new 915
I had the 915, when the car was making 360rwhp and it took 3 months before she blew.
Now I have a 930 short bellhousing trans, just changed the clutch disk and added more clamping force to the pressure plate. We should be going to the dyno again- looking for 550+rwhp. There are many factors, to gaining hp, first is tuning, fuel, turbo, intercooler and headers. Quality of the product.(will it last?) Anyhow, good luck. |
488.4RWHP
465lb-ft what muffler are u running...i could have just missed it...anyways my guess assumes a good free flowing muffler.... |
Thanks mppickett, i didn't know anyone made the 36-1 wheel for the 911. I think that the final straw in deciding to use an EDIS module and coils for my MSNS-E setup. thanks again
http://pickettweb.com/Porsche/engine3.jpg |
It really depends on how much boost your gonna run.....I would say
425HP at the crank. |
I'm shooting for 1 bar boost in 3rd gear.
I look forward to seeing how long the trans lasts.
I would like to keep my 915 in my future 3.6 turbo in my 72 but I keep hearing it will blow. Hope she holds. |
I agree. I really like the 915. I'm actually pretty easy on the trans in terms of shock (I don't drop the clutch or power shift). I do think the torque is going to catch up with it sooner or later, though. Rarlyl8 has had pretty good luck with his if I'm not mistaken.
my guess at 15lbs is 417 hp , now to get nitpicky are the numbers gonna be sae corrected hp or observed?? :)
I was going to report SAE corrected numbers for the purpose of the contest. Elevation of the dyno is around 350 above sea level and the temperature tomorrow should be in the low 80's. The weather is supposed to be partly cloudy. I suspect that there won't be much difference between SAE corrected and raw DynoJet numbers.
My guess is 395 hp
427 hp
403 ft-lbs I'll take the stock wastegate spring. ;) -Rod |
Oh, I know, I know, Oh Oh SmileWavy...
Very similar setup from mine except you got the EFI goodies and twin plug. Since mine on a DynoJet 249C got 403 RWHP/390 RW Torque, I say you should be somewhere around 440.233 RWHP and 440.245 RW torque +- .001 ;) During my dyno run, I filled my tank with VP MS109 just to be safe :D Make sure you have a big a** fan blowing in the back and maybe put a big cardboard tilted 45 degree deflecting air down to the IC. |
PS is a measure of Power used in Germany for awhile...
No OCF for me this year and I hope that is not the same Marianne who has an office next to mine... Since you didn't like the PS units I will change my guess (estimate) to -- let's see now -- 73980.35 calories/sec. And if you don't like that one, then how about... 3.0959 * 10^12 ergs/sec ? |
My guess is between 350 and 375 for hp at the wheels.
415hp is my guess.
392 torque. |
Where are you located Mike? And where are you getting the dyno tuning done?
Good luck! I'm in Concord. Just wondering how far away you are... Brian |
Hi Brian,
I'm over in Durham. I usually use Jeff Creech over at Carolina Auto Masters for dyno work. He's a Corvette guy but he's really good to work with :) |
427.5 ft-lbs of torgue with 432.5 HP
389 bhp. With other words, around 354hp at wheels.
1 bar boost and 50 lbs injectors will be the limiting factor here......I'm gonna say 460 rwhp with around 425 lbs/ft of torque.
If using a DynoJet 248C, I'll say 445 RWHP and 420 RWTQ.
| All times are GMT -8. The time now is 04:24 AM. |
