3.0 engine mod question
If I took at stone stock 3.0 ( in an 83SC ) with CIS and added SSI's and a Monty 2 in 1 out muffler what kind of torque and hp increase should I expect? How about if I added PMO's--any power increase there without intake port mods ?
What is the real bottleneck in the system--CIS, factory exhaust manifolds, 83 model intake ports , stock cams ???
Like to hear from you who have made changes and what was the best combination without changing pistons & cylinders. I also may go to a light flywheel for increased throttle response. Just tell me the real scoop--what works and what is a waste of $$$.
Thanks !!!
Don
Don
83 SC Widebody Coupe
86 Carrera Coupe
Old 07-06-2006, 08:04 PM
iamchappy's Avatar
Hands down best bang for the buck,
911SC Turbo
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 07-06-2006, 08:15 PM
oneblueyedog's Avatar
Went with a Elgin cheater camset and euro pre muffler. Timed for the high end revs and boattailed the webs. Sachs sport clutch and pressure plate.
Stock P&C (new).
Racing springs and Raceware rod bolts installed for future racing and tuning.
I'd say play with cams and go for a T-bitz without going too radical with the stock engine.
78SC coupe, Silver Metallic
Old 07-06-2006, 09:07 PM
A Quiet Boom's Avatar
Here's what I got with backdated exhaust and rebuilt Zenith's with 36mm venturis and drilled jets. As you'll note in the thread there should be more power to be had now that I've got my new fuel pump installed.
http://forums.pelicanparts.com/porsche-911-technical-forum/291307-dynojet-fun.html#post2684733
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 07-06-2006, 11:45 PM
Thanks Wayne !!!
Just 2 questions--are the S cams enough to make it "fun" or should I go GE20 or 40? I have heard that 964 cams are good too. How would the above fall in order of mild to wild?
Thank you for your time and advice !!!
Don
86 Carrera Coupe
Old 07-07-2006, 12:56 PM
Author of "101 Projects"
Wayne 962's Avatar
964 = only good for CIS - they are a relatively weak cam
S cams or Mod S cams = use with carbs
You won't regret it...
I've got whole chapters on this stuff in the Engine Rebuild Book...
-Wayne
Old 07-07-2006, 02:08 PM
GOT TURBO..
MobileWrks's Avatar
AHHH Wayne.....
Thats what i was going to do when i get my 75 roller home....OHH well...
Yes delaneyd, that set up will get a smile put on your face... A perfect todo on a 3.0L. I got my case split ready for all my notes of todo;s and wayne hit the nail on the head.. But for me, im adding a few things extra just for fun... hmmm
Old 07-07-2006, 09:37 PM
