3.0 engine mod question
If I took at stone stock 3.0 ( in an 83SC ) with CIS and added SSI's and a Monty 2 in 1 out muffler what kind of torque and hp increase should I expect? How about if I added PMO's--any power increase there without intake port mods ?
What is the real bottleneck in the system--CIS, factory exhaust manifolds, 83 model intake ports , stock cams ??? Like to hear from you who have made changes and what was the best combination without changing pistons & cylinders. I also may go to a light flywheel for increased throttle response. Just tell me the real scoop--what works and what is a waste of $$$. Thanks !!! Don
Don 83 SC Widebody Coupe 86 Carrera Coupe |
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
Went with a Elgin cheater camset and euro pre muffler. Timed for the high end revs and boattailed the webs. Sachs sport clutch and pressure plate.
Stock P&C (new). Racing springs and Raceware rod bolts installed for future racing and tuning. I'd say play with cams and go for a T-bitz without going too radical with the stock engine.
78SC coupe, Silver Metallic |
Here's what I got with backdated exhaust and rebuilt Zenith's with 36mm venturis and drilled jets. As you'll note in the thread there should be more power to be had now that I've got my new fuel pump installed.
http://forums.pelicanparts.com/porsche-911-technical-forum/291307-dynojet-fun.html#post2684733
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
Author of "101 Projects"
S cams, JE high compression pistons, Weber or PMO carbs, SSIs with Dansk muffler...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks Wayne !!!
Just 2 questions--are the S cams enough to make it "fun" or should I go GE20 or 40? I have heard that 964 cams are good too. How would the above fall in order of mild to wild? Thank you for your time and advice !!!
964 = only good for CIS - they are a relatively weak cam
S cams or Mod S cams = use with carbs You won't regret it... I've got whole chapters on this stuff in the Engine Rebuild Book... -Wayne
GOT TURBO..
AHHH Wayne.....
Thats what i was going to do when i get my 75 roller home....OHH well...
Yes delaneyd, that set up will get a smile put on your face... A perfect todo on a 3.0L. I got my case split ready for all my notes of todo;s and wayne hit the nail on the head.. But for me, im adding a few things extra just for fun... hmmm |
