EJC EJC is offline
EJC's Avatar
Porsche Crest Trailing Arm/Spring plate bolt question
I have a '74, 911 and am replacing the rear torsion bars and installing new adjustable spring plates. The lower bolt on one side, which is holds the spring plate to the trailing arm is frozen!! The nut is off, but the bolt is solidly in the arm. I would appreciate advice--does this need to come out to be inspected?? Or is this just a happy bolt that will continue to do its job when reassembled. Thanks.
Old 07-07-2006, 10:31 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
That bolt stays there. The nut you removed is normally loosened to adjust toe or camber, I can't remember which.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 07-07-2006, 10:59 PM
Chuck Moreland's Avatar
Zoanas, the front bolts adjust camber and toe. The lower bolt simply secures the spring plate to the trailing arm.
EJC, with the nut off that bolt should come out pretty easily. Have you removed all 3 nuts that secure the spring plate to the trailing arm? You do have the car in the air with no wight on this corner right? Gotta pic?
Chuck Moreland - elephantracing.com - vonnen.com
Old 07-08-2006, 09:57 AM
UFLYICU
ZOA NOM's Avatar
A picture is worth a thousand words:
Thanks, Chuck, you are correct. I was thinking about the oval shape of the bolt holes at the trailing arm when I posted above. Those two nuts need to be loosened to make any adjustments to toe or camber.
prc-racing.com
Old 07-08-2006, 10:59 AM
EJC EJC is offline
EJC's Avatar
It is indeed one of the bolts that holds the trailing arm to the spring plate. Car is in the air, and the other bolt is free, and the camber and toe bolts are also free and out. Space limitations make a 1/2" break bar almost impossible due to trailing arm. Sprayed wd40 & pb blaster to no avail. I have not gone to the heat yet, but is it really a problem? Thanks for the input.
Old 07-08-2006, 03:58 PM
Used Up User
imcarthur's Avatar
Are you sure the bolt is not just pinched due to the force of the torsion bar? Have you tried jacking up the edge of the springplate & relieving the weight? I started to strip one because of this . . .
Ian
'87 Carrera Cab
Old 07-08-2006, 04:37 PM
Used Up User
imcarthur's Avatar
And it was the lower one btw.
Ian
'87 Carrera Cab
Old 07-08-2006, 04:38 PM
UFLYICU
ZOA NOM's Avatar
I think Ian's onto something. I had the same problem with mine, also the lower one. I put a small bottle jack under the corner of the spring plate and lifted it just enough to relieve the pressure on the bolt.
prc-racing.com
Old 07-08-2006, 05:53 PM
randywebb's Avatar
Now somebody write which way to turn each nut does what/how much and we have a nice pic of suspension adjustment...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 07-08-2006, 11:32 PM
EJC EJC is offline
EJC's Avatar
Photo gives a better idea of my question.
Old 07-09-2006, 12:05 PM
lateapex911's Avatar
So, basically, you're saying that bolt has become oxidized in there?
I would try mild heat on the surrounding area, and then thread a sacrificial nut or two (one as a jam nut) on the threads, with the outer suface of the nut proud of the threads. Now, a few mild raps with a hammer might do the trick.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 07-09-2006, 12:09 PM
EJC EJC is offline
EJC's Avatar
It must be oxidized, almost as if it were welded. What is the downside of leaving it as is and then doing the reassembly? Any thoughts about that?
Old 07-09-2006, 12:19 PM
Oh....I thought you wanted it out as a matter of course, LOL
If the threads are good, then it's doing the job, and should continue to....
But, it will continue to oxidise, and isn't too likely to get better. So, if you can get it out, why not and replace it wth a fresh properly plated version. That would be, in my eyes, the way to do the job 'right'.
But I would venture that it will function fine as is.
Old 07-09-2006, 12:32 PM
UFLYICU
ZOA NOM's Avatar
Try putting the box wrench on it, and use an air chisel vee bit on the open end while you turn it. Or simply a BFH to tap it loose. Worst case, you twist the head off and have to drill it out.
prc-racing.com
Old 07-09-2006, 01:41 PM
EJC EJC is offline
EJC's Avatar
Thank you all for the input, very helpful. Other ideas always welcome. I will let you know when I get it out. Thanks again.
Old 07-09-2006, 03:42 PM
Used Up User
imcarthur's Avatar
BFH is what I'd use & just buy a new bolt. There's nothing holding it in but rust.
Ian
'87 Carrera Cab
Old 07-09-2006, 04:54 PM
EJC, I had one exactly the same when I did my torsion bars. In fact, one of them snapped right off, and one was left like yours. The alloy arms and the steel bolts aren't a good mix, and after salt, water and time the aluminium and steel will react and virtually weld the bolt in place. I tried for 2 days to get the bolt out and ended up cutting it flush, and drilling it out, like I did the one that snapped (only did it bacause I had to do one anyway). If you don't fancy drilling it out, then leave it in, I can't see it doing any harm
Old 07-10-2006, 01:42 AM
EJC EJC is offline
EJC's Avatar
David, thanks for the follow-up. I was somewhat lucky and able to use the propane torch and hammer method. It did come out, but there were several uneasy moments. I was not looking forward to drilling it out. EJC
Old 07-11-2006, 08:59 PM
I just tackled this in the last couple of nights. It seemed my bolts had formed threads onto the trailing arm. I gave the bolt a couple solid wacks with a rubber mallet to break the bolt free then backed it out with a wrench. It might be worth a shot.
Regards,
Kris
1986 Targa
1993 Corrado VR6
2005 325xi
2010 135i
2011 X5d
Old 07-12-2006, 06:51 AM
