Does warm idle setting affect cold idle setting on a Carrera Motronic?
I'm kind of fine-tuning now after sorting out several issues with this car, which I acquired a few months ago, and I recently had my CHT sensor professionally installed I (which turned out to be a good thing, as the sensor was stuck in the head and needed to be retapped after removal). The mechanic reset the idle, as it was idling at about 1200 (probably hillbillied-up by my PO). Now it seems too low, it idles at around 650 warm ( surprisingly smoothly) and it has now become difficult to keep running right after cold start-up. Are these settings correlated ( proportional to each other) or are they separate issues completely?
86 3.2 Carrera Cabriolet
99 Ford Explorer Limited V6 ( disgustingly reliable) support vehicle/work truck
2000 BMW Z3 ( gone and forgotten...I got bored)
Old 07-11-2006, 10:43 AM
Irrationally exuberant
ChrisBennet's Avatar
If the motor is running correctly the idle should be around 880rpm and not vary much. The computer (DME) controlled idle stabilizer valve (ISV) controls the idle speed. If it idles at 650 or 1200 something is not working correctly.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 07-11-2006, 11:38 AM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
You may want to reset your idle, if you CHT was off last time it was set, you may have to return it to normal before raising the idle back to normal.
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 07-11-2006, 12:42 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Check the mixture with a gas analyzer before messing with the idle setting. If the mixture is off just a tad, it could be affected by temperature changes.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 07-11-2006, 02:13 PM
