Angry What is this hose and why is it leaking???
Well I seem to have found another oil leak! There is a hose that hangs down right above the HE. It is bolted to the back of the oil cooler. Does anyone have an idea what this is for and what I can do to stop the leaking? It doesn’t drip like a valve cover leak it is almost like a vapor. Any help would be greatly appreciated.
By the way thanks again for the recommendation to Kerry Singley. They did the rear-end alignment and diagnosed another problem I had.
Old 07-14-2006, 04:00 AM
Oh Haha's Avatar
A bigger picture would be helpful. I can't tell the location of the hose in that picture.
Pacific Blue
Wayne
Old 07-14-2006, 04:18 AM
Yeah I tried to get a larger one but its in a tight place. The top of the hose looks like it goes up towards the top of the engine. I checked the oil pressure switch and it is not leaking from there, but that is the general area. I was thinking it might be connected to the crankcase breather cover???
Old 07-14-2006, 04:39 AM
Oh Haha's Avatar
Without having my car to look at I can't help. It may be a "road hose". Semi trucks have used them for years to let the crank case pressure relieve itself into the atmosphere. Can you follow the hose and find where it goes up top?
Pacific Blue
Wayne
Old 07-14-2006, 04:47 AM
Yeah I plan on checking it when I get home from work. The car was too hot last night to dig around in there. Thanks for your help I guess we are the only ones awake.
Old 07-14-2006, 04:51 AM
safe's Avatar
I think its this hose/container his picture is showing.
It looks like it drains oil from the intake, I think...
Magnus
Old 07-14-2006, 05:03 AM
YES thats it! Do you know where its supposed to go and what it does?
Old 07-14-2006, 05:10 AM
Oh Haha's Avatar
Cool. Thanks Magnus.
Pacific Blue
Wayne
Old 07-14-2006, 05:12 AM
Friend of Warren
It doesn't go anywhere. It is a drain hose from your airbox.
Kurt V
Old 07-14-2006, 07:06 AM
Is it supposed to be re-directed somewhere? It drains directly onto the heat exchanger!
Old 07-14-2006, 10:19 AM
Unless I am missing something not sure how that hose could be with the air box???
Any Help??
Old 07-14-2006, 12:22 PM
rnln's Avatar
how can air box has oil?
Fat butt 911, 1987
Old 07-14-2006, 12:27 PM
bigchillcar's Avatar
agree with kurt. it isn't really supposed to leak much or 'continuously'..just if oil winds up in the airbox by accident, perhaps in an overfill condition. oil hitting the hot heat exchanger is just outdated porsche technology used for a 'sensor'..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Its so odd though because the oil level has been perfect for the last 1000miles (I check once a week). The air box is dry so I am at odds I guess. I checked and the other end is hooked up under the fuel dist. It seems as though it was clogged and now its not.
Old 07-14-2006, 12:50 PM
