issue with sway bar installation
I recently installed a Carrera sway bar in the rear of my 76' S. I didn't recall having this issue when I first installed it..but!
The problem is that when I looked at the clamp that holds the bar to the body I see that the bushings there are squezzed out of the clamp. I adjusted the clamp bolts until the clamp touchs the mount on the body. Is this wrong? Should I loose the clamp bolt a little? I am assuming that the clamp will be the same for the carrera bar (21mm) than for the stock (18mm). Is this correct? Thanks
Mario '76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger '15 GT3 Last edited by mmasse; 07-19-2006 at 07:22 AM.. |
Mario,
The rubber bushings are different sizes, bigger hole for the 21mm vs the 18mm. The clamps are the same.
DOUG '76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's. '85 911 Carrera, stock, just painted, Orient Red |
Thread Tools | |
Rate This Thread | |
