Turn Signals Switch Problems
Some weeks ago the turn signals quit on me. I just cleaned up the circuits with contact cleaner and lubricate with dyelectric Grease. I try them and they began working ( for about 2 weeks).
All the sudden they quit again but when I actuate the turn signals they will remain lid but will not flash. I noticed that the Flacher is the same for the signals and for the emergency flacher that works. Any suggestion? Cordially Vic
bump
Vic ![]()
If the emergency hazard lights work, it is likely not the flasher. It is probably either the stalk switch or the power source. The emergency hazard lights use unswitched power while the turn signals used switched.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Stalk switch..?
Where can I find this sw? It will be very nice if I can see it . I have a PDF Porsche part's Catalog and the search engine will not give it to me. I'll try the Pelican search. If you have a Part # for a 1982 SC I'll be really nice .. Thanks for the help. Vic
This is the one...911-613-305-01-M78, but I would try to troubleshoot it some more first. Try this link:
turn signals don't work
Very Nice.., thank's
Vic
Turn Signal switch levers
Well....... it seems that I have a lot's of wire check up because I instal a new turn signal switch today.
Besides the new switch what other items should I check..? Vic
Ok guys..! One quick question .
I'll like to check the running lights and the turn ligths cables with live wires (continuity) and switch "on" but I don't want to burn my MSD . I know I have to unplug the FUEL PUMP RELAY, ok then.... What other relay I have to unplug? Cordially Vic
bump
Jusnt in case someone reply...!
I just try troubleshooting the cables and found that only one of the rear driver side lights work. I test the connector pins inside the engine compartment and found power in the one that lid's the working bulb but no power in the other's. I'll like to know.. How do the cables run from the left connector inside the engine compartment to the front of the car. I notice that the cables runs behind the Fuel Accumulator and the Fuel Filter ...! them where to? No problen in the right side light's still have to work on the signal light's. Cordially Vic
