Mark Davis's Avatar
Speedometer and Odometer question
Is it possible for the speedometer to read incorrectly and still have the Odometer reading correctly.
Thank You
Mark
Old 07-25-2006, 08:01 AM
Friend of Warren
Yep. They run off separate mechanisms. I would suggest this is the rule as opposed to the exception on most 911's.
Kurt V
Old 07-25-2006, 08:10 AM
Mark,
Thats a great question. If the odo works right, why are most speedo's optomistic by 10%. Is this one of those marketing decisions?
How does the odo get it's signal? Maybe my Carrera has less mileage than it shows.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 07-25-2006, 08:48 AM
Friend of Warren
Originally posted by 2.7RACER
Mark,
The "optimism"is built in at the factory for the speed reading. However the odometer is geared to be accurate off the signal. This is not limited to Porsche. Many manufacturers do the same thing.
Kurt V
Old 07-25-2006, 08:55 AM
Mark Davis's Avatar
Thanks for the information. It is nice to know that the milage is correct on the car. Now all I have to do is have the speedo fixed so I don't have to explain to the girl friend that I am not realy going that fast.
Thanks again
Mark
Old 07-25-2006, 03:18 PM
